Rattling at idle
  • Thread starter Thread starter 5point0dude
  • Start date Start date Sep 24, 2008
5point0dude
51
Sep 24, 2008
  • Sep 24, 2008
Hey guys, I have a question that I cannot find the answer to. I have a '91 5.0 LX and when I start the car it starts up fine, but a second or two after startup I'll hear this loud rolling/rattling/clanking sound for a second then it goes away and the car is fine. As I'm driving, I hear nothing out of the ordinary, but when I'm at a stoplight idling for a little bit, I start to hear the same noise from startup, only now it keeps going and going the whole time I'm idling, and the second I touch the gas to go, the noise stops. I'm not sure but it sounds like it's coming from under the car, like the transmission or driveshaft, and I do have a 5-speed. To me, that's where it sounds like it's coming from, sometimes I can feel the vibration from the rolling/rattling/clanking under the floorboard. Also, whatever it is, it sounds like it's spinning or rolling, and it sounds kind of heavy too. Any info would help because I have no clue where to start diagnosing. Thanks.
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Sep 24, 2008
  • Sep 24, 2008
heatshield rattling? usually it does it all the time at idle. this is for the catalytic converter btw.
MahFiVeOh
531
9
49
Ontario, Canada
Sep 24, 2008
  • Sep 24, 2008
I had something very similar happen last year.One of my cats went bad and started to rattle.It almost sounded like an engine knock.Jack up your car and see if it rattles when you tap it with your hand or rubber mallet.
5point0dude
51
Sep 24, 2008
  • Sep 24, 2008
Thanks guys, I completely forgot about the cats, I remember reading about someone else having this problem, I'm pretty sure that's the problem now. If it's the heat shield or cat itself, what's your suggestion on fixing it? Thanks.
MAC'n89Blckstng
1,012
NJ
Sep 24, 2008
  • Sep 24, 2008
Get an off road x pipe and your car will be louder and a lil faster.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Sep 24, 2008
  • Sep 24, 2008
Either tack weld the shield so it doesn't vibrate, or take it off completely.
5point0dude
51
Sep 24, 2008
  • Sep 24, 2008
Thanks everyone. I was planning to get a catalytic x-pipe in the future to gain the extra ponies, sound better, and pass smog at the same time, but now I have a good excuse to go get one now.
Cobra912
1,777
11
39
Wish I was anywhere but here
Sep 25, 2008
  • Sep 25, 2008
had the same problem on my old notch. cat heat sheild rattled like crazy
Stableboy
91
Perryville MD
Sep 26, 2008
  • Sep 26, 2008
I have the same problem. I know the shield is there for a reason, but anyone heard of issues if you remove it?
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
