I've used the EZ wiring kit; more specifically the mini 20. I can tell you that unless you're going to heavily modify the car and options you don't need a 20 I didn't use a bunch of wires, then again I'm running a stock car. Things like an electric choke, an electric fan, a A/c; window motor power, electric fuel pump. All that are things i didn't need.
The modification that is needed is the connectors. Yes, if you try and search for all new connectors you will have some trouble. I couldn't find most of the connectors so I had to reuse the older ones.
By connectors i mean for example, to pass the wires throught he firewall on the driver's side I had three options, to reuse the old master disconnects, to cut a new hole int he firewall and use summit racing's bulkhead connector, or to just run the wires through holes existing in the firewall. I decided to just use the old master disconnect, I simply didn't use the wires that looked really bad or were corroded.
Things you would need if you are going to rewire the car, are connectors, perhaps a solder, a wire crimper, a multimeter (but not totally necessary, good to have though), and patience.
Wiring hte car isn't as hard as it seems, it gets easier as you get into it. I'm not sure about the painles harness but from what i've seen/heard they have the stock like connectors with them.
