  • 1994 - 1995 Specific Tech
Read my S. Plug
  • Thread starter Thread starter wytstang
  • Start date Start date Nov 27, 2005
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Nov 27, 2005
  • Nov 27, 2005
All my plugs are running/firing fine. For some reason my #8 plug seems to be chipping the insulator off. I believe it called "Splashed deposits" here are some pics.
The reason splash deposites happen is usually caused by dirty carburetor bores or air intake. But if this is true then why only #8 wouldn't more then just one do this. This is the second time this has happend to the same cylinder. I noticed a loss in higher end power and having a left bank o2 reading lean (maybe one triggering the other). I'm going to run some seafoam maybe tommorrow and swap to hotter plugs (autolite 26). I replaced it with a good used plug from my last plug swap and noticed the power back up to par. Here is the link that I found a pic some what similar to what mine look like http://www.theultralightplace.com/sparkplugs.htm any thoughts or comments on what is really going on (or thing is happening) are welcomed.
RIO5.0
6,892
N.H.
Nov 27, 2005
  • Nov 27, 2005
I don't know about the splash thing ??? That plug looks fouled to me...All the Black crud...that should be Tan of sorts around that rim...That tip looks good, burnwise but the remainder looks like ass...
She looks all carboned up for sure...
OHM your plug wire for that cyl and see if its in spec?? Looks like its loading up with fuel???
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Nov 27, 2005
  • Nov 27, 2005
Second set of wires first being msd 8.5 currently taylor wires. Same cylinder two different plugs and wires same end result being the insolater being chipped. I starting to think maybe my injector is squirting fuel directly at the plug. I looked at my last plug and it's chipped exacly were this one is. I think I'm going to run a hotter plug in that cylinder and see what happens. Thanks for your input RIO any more thought/input please feel free to reply all others are welcomed as well.
RIO5.0
6,892
N.H.
Nov 27, 2005
  • Nov 27, 2005
Maybe swap the injector to another cyl and see if it follows??
Good luck to ya...
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Nov 27, 2005
  • Nov 27, 2005
Don't really wont too but I may just have to do that . I pulled the spare plug I put in there and it already has an area whiter then the rest. Its the same spot the other two are chipped at.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Nov 27, 2005
  • Nov 27, 2005
Anyone else????
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
