Alright, after getting beat up over considering going to a carb, I'm now considering staying injected. I've heard from quite a few sources that the stock pcm in the 94-95 SN's doesn't like to play well with aftermarket cams. This being said, driveability is a major concern of mine while I'm considering my options.
If I was to keep my stock 95 GT cam and add say a set of Y303's, 1.7 RR, and a Cobra or GT-40 intake what could I realistically expect for power out of this combo?
I'm looking in relation to possible 1/4 mile numbers, that's something I could compare things to that we've all experienced. I'm not looking at this point to also swap in a MAF, injectors, or throttle body, and I realize the setup might suffer slightly from it. I'm just looking to get the parts I already have in use to see what they'll do.
I already have a new clutch, 3.73 gears, Comp Eng rear lowers, off road X-pipe, and smog pump deleted. I'm considering putting an MSD 6al on that I have on the shelf, if for nothing else but the rev limiter, and I'm looking for a set of pulleys.
FRPP used to advertise a setup similar to this that supposedly put out 290 to 310hp at the flywheel, how does that relate to track times on these cars taking into consideration all the variables(wheel spin, weather, stupid driver).......??
Sorry for probably rehashing old topics, but isn't that how new topics get started
. I went with the Steeda 19, which isn't the most aggressive but is said to work good with our computers
