REALLY BAD ROCKER TICK....Please Help
  • Thread starter Thread starter Black1987Stang
  • Start date Start date Nov 8, 2006
Black1987Stang
1,422
Jersey Shore
Nov 8, 2006
  • Nov 8, 2006
Ive had a rocker tick on my driver side for about 7 months now, still the same after numerous oil changes... a month ago my oil pump had locked up twisted and broke my oil pump shaft, put in a new pump and hardened shaft, cleaned the inside of the pan of all the old oil, changed oil filter etc....Once I got it back running there was no more rocker tick at all, i was like hell yes, then about 500 miles after, it started coming back little by little everday, I had put about 10 dyno pulls on that oil so i figured it would be good to change it anyway so saturday I change the oil thinking that was the problem since when i did the pump i changed the oil and it was all good...I had put about 30 miles on the new oil and it was still the same, I raced a vette 4 times, smoked his ass everytime of course n shut him up telling me he had "405hp" when he only had prob 250rwhp if he was lucky, (there were no other cars on the road btw and im very cautious with that stuff) anyways after that it got about 2x as loud and now im not sure if i should even try changing the oil again or try n find which rocker it is and readjust it n hope it helps out???.....by the way the lifters are a year old and have readjusted them two times already a while ago and didnt help out.....BTW how does everybody adjust ur rockers, do u set both when that cylinder is on the base circle of the cam OR adjust the intake when the exhaust valve is closing?? or opening?? (forget which it is) and vice versa for the intake Thanks Sean D.
z2o_what
309
princeton, WV
Nov 8, 2006
  • Nov 8, 2006
i have never adjusted ford rockers, just got them tight. (never had any problems)
but when i adjust sbc rockers:
with the engine running and the valve covers off, loosen each arm until they start rattling. the tighten them 1 1/2 turns.
jtfairlane
468
  • Nov 8, 2006
If you're trying to imply that you somehow you adjusted your lifters but not your rockers, that's....not really possible. You would be doing the adjusting at the Rocker nut for setting zero lash on a hydraulic lifter anyway, so you would be influencing the adjustment of the rockers by just doing that.
Here is a link to Comp Cams instructions for one of their types of stud mount rocker arms. Assuming you have stud mount rockers, and not bolt down, these instructions should work well for you and take care of any rocker mis-adjustment issues. Another possible issue might be if your rocker studs (again, assuming you have stud mount rockers) were not torqued properly, and might be slowly backing out, stranger things have happened.
The link: http://compcams.com/Technical/Instructions/Files/250.pdf
Black1987Stang
1,422
Jersey Shore
Nov 8, 2006
  • Nov 8, 2006
nah I just meant I put in new lifters when i built the motor so they "shouldnt" be bad. and that I had adjusted them twice hoping to fix the ticking when it had first started doing it but no luck
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
