fivepointNO
- Jun 7, 2002
- 746
- 0
- 0
I think you're VERY close to having this running, and either your timing is off or you have a defective distributor(or a part within). You're getting fire and you have fuel and air... With correct timing, you should hear it running.
My best guess would go to either being 180* out or just a couple teeth off in either direction.
Just to make setting TDC easier, remove all plugs. I expect the dampner bolt to be either 15/16's or 7/8's and with the proper deepwell socket, you can turn over the engine slowly to verify proper positioning. Remember, when turning 180* to NOT move anything but the rotor position once the distributor is lifted. Getting backfires is significant because it usually means you're close. With that, consider turning the rotor only a couple teeth in either direction. You can make final timing adjustments by twisting the entire distributor once it's running, but short of running, you'll do no additional good in that adjustment.
Seems the advice so far is pretty spot on so... unless you have a faulty part in the distributor(which doesn't seem to be the case), proper timing should fire your engine, allowing that sweet rumble you seek.
I suggest you get and install the pointer before continuing. No sense driving yourself mad over that and it's an absolutely integral part of setting timing properly.
