  • SN95 4.6L Mustang Tech
Really stupid coolant question...
  • Thread starter Thread starter MyEarsHurt
  • Start date Start date May 22, 2005
MyEarsHurt
918
  • May 22, 2005
Okay, my headswap is done, everything is in place, ready to fire it up, but I have not added the coolant yet. Do I just need to fill the coolant reservoir and then keep filling it while the car runs? I have never drained a coolant system before, so I have no idea what to do now that there is zero coolant in the engine. Should I pour some coolant into the block through the crossover on the intake, and then fill up the coolant reservoir too? Maybe its just a stupid question, but I need some help on how to do it right...dont want and hiccups on start up
highvolts
20+ Year Stangneter
Sep 1, 2003
436
Ohio
May 22, 2005
  • May 22, 2005
subscribing
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 22, 2005
  • May 22, 2005
add the coolant through the resivoir. just keep adding it. make sure that the front end is jacked up and that will help get all of the air bubbles out.
ocbaud
239
Midwest City, Oklahoma
May 22, 2005
  • May 22, 2005
i've always filled it up at the thermostat housing and then the radiator after that, but of course this is on older cars. havent worked on a mustang yet...
01SN8K
135
  • May 23, 2005
fill it like suggested with the front end raised on jackstands. fill it then start the motor and fill as needed.
Red mustang Gt 46
601
Good ol' Maryland
May 23, 2005
  • May 23, 2005
After you fill and run the car (warmed up), let it cool completely...massage the upper and lower hose with the reservoir cap on and off (front end elevated). Top off reservoir with fluid. This will help fill the block completely and remove air. Do this a couple of times to be sure.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 23, 2005
  • May 23, 2005
what i usually do is fill the overflow bottle. and while the engine warms up i bring the engine rpms up too 2500 or so. this will break up the air pockets in the heads and heater core.
DO not just fill and go. it's going too to take a little while of bleeding too get it all out. and without one of cooling system fill machines the only way too get the air out is the way i mentioned. be ready with more coolant because as the air pockets are pushed out the coolant level will drop.
have the heat on high blowing out the vent when you have good heat at idle recheck the level and put the cap on. recheck again after you drive it in case of more air int he system.
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
V
Engine Coolant Leaking?
  • vinzo
  • Jan 26, 2025
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
