Rear 02s the same?
281Ponies
190
I need help confirming my thoughts here.
I've been running a set of PnP MILs for a while and yesterday one got against the mid-pipe and began melting the plastic where the 02 plugs into the MIL. I knew when it started because the SES light blinked about 15 times and then stayed on. It didn't burn all the way threw but I'm sure the solder probably ran shorting one or the other out.
My question is, I have a set of rear 02s I bought for my 00 but wondering if there's any difference in voltage, cats, etc. between a 00 and 02GT. I want to replace the 02 and try the MIL before I determine just what I have to replace.
Rear 02s for a 00 should work fine on 02... right?
Thanks,
-Cale
2002BLGT said:
should be the same , I would call ford dealer and check with them .
Well, I thought of that but wanted to check here first... in case the service department is only interested in making a sale and says there is a difference.
I'll see if someone who knows for certain chimes in before making a call.
Thanks though,
-Cale
All FOUR O2 sensors are the same! They are all narrow band O2 sensors and only differ in connector color and keying. For the rears, use whatever you've got laying around as long as they keep the light off thats all that matters. From my own experience and helping others, I've had best luck with OEM Fords on the front.
