Hello folks, I'm wanting to replace my rear metal brake lines on my '68 while I've still got it up on jackstands.
I've already replaced the metal line going from front to rear and the rubber hose that connects that line with the rear axle. My question is how hard is it to replace the remaining two brake lines that are on the stock 8" rear axle?
I've noticed a couple of clips that look like the bottoms of them are welded or brazed to the axle. Would it be possible to pry open those clips to remove the old brake lines and then install some new brake lines?
I'm wanting to bend my own brake lines for this as well. The front to rear brake line was around 10 feet long(I used two 5 feet 1/4" lines). I think I did an ok job bending those lines so I'll probably try bending new ones for the axle if possible.
Anyone know if these clips on the rear axle can be reused and how they are attached, and if not then how do you go about replacing the brake lines on the rear axle?
Thanks,
Randall
Thanks,
Randall
