Rear axle bump stop???
93octane
46
Those that have installed lowering springs on your mustang did you change out the rear axle bump stop??? I cut mine but don't know if its worth buying a new one???
http://store.summitracing.com/default.asp?target=product.asp&p=2628&searchtype=ecat
If you dont install the shorter bumpstop you will not have full travel with the shorter springs. You will bottom againist the stock stop on the smallest of bumps. If you compare the two the stocker is about 5 inches tall the aftermarket is what 1.75-2 inches tall maybe.
