Drivetrain Rear axle difficult to slide in
fox racer v2
88
44
28
32
Brooklyn
So, wrapping up a rear disk conversion on my 89LX, and had an issue that’s concerning me on the rear axle:
When the caliper mounting plate is installed on the axle housing, the axle is very difficult to slide in. I’ll define very difficult as: to install, both palms on the hub with fingers on the backing plate and I have to firmly squeeze. To remove, I have to put a foot on the LCA for leverage to pull out. When the axle is seated/installed, it spins just fine with not binding (can spin the axle with one hand.
Here’s the rub: if I remove the caliper mounting plate, the axle slides in easy-peasy with finger tips. The caliper mounting bracket is a brand new Ford piece, and the axle shout was cleaned (first a screw driver to remove flakes, then a wire brush/scotch pad and brake cleaner).
Could the mounting plate really be deforming the axle housing that much? Has anyone ever had this issue?
  • Sponsors(?)
stormsedge
304
89
38
Here
Maybe. Throw a straight edge on the new mounting plate flange at a couple of different angles just to be sure it isn't warped, miscast or mis-milled. Is the new plate sliding easily onto the axle snout and seating well without having to draw it down with the bolts?
fox racer v2
88
44
28
32
Brooklyn
That’s the plan. It went up flat, bolts drew down real easy. But am going to pop it off and check those points.
Even Ford Tech said “we’ve never heard of that. Check the mating surfaces and hardware”
giddyup306
3,041
36
My vote goes for hardware. The only time I have seen any axle housing distort by any amount worth noting is on the 9.75" that you have to spread the pumpkin to get the gears in and out. And the cases are made from aluminum. Are the mounting plates on the wrong side by chance? Had that happen once when I was putting the brackets that hold the pads in were on the wrong side preventing the wheel from going on correct. Never saw that before or after. My boss was a Master ASE tech and he said he never saw it either.
fox racer v2
88
44
28
32
Brooklyn
Correct side/face thankfully. I seem to find new and improved way to break these cars... My buddy initially forced the plate on when we first installed, so it had to be a hardware issue. We finally fixed it though
The ears on the axle shaft were bent a bit - enough the bolts were difficult to get out. A few taps the BFH and a check with a square to get straight to the eye. Then took a wire brush/metal file to really clean the mounting surface take down any bumps/clear any rust or gunks build up. Finally we checked the caliper plate for true (look perfect to the eye, these Ford pieces are beefy...) and cleaned up the holes so the bolts easily go in/out.
After all of that, the axle was significantly easier to slide in, but still a little more resistance than I liked - so we took a brass drift and carefully tapped on the bolts (from the outside, not the bolt head side and witht he caliper plates properly torqued down) and the axles slid super easy/smooth in an out. New bearings/seals to be safe and everything is like stock
Thread starter Similar threads Forum Replies Date
PonyGTrider Rear axles stability 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 36
BugsOli Drivetrain Passenger side rear axle play and clonk Fox 5.0 Mustang Tech 3
D 1967 Ford 8" Axle 1965 - 1973 Classic Mustangs -General/Talk- 3
E Drivetrain Rear axle gears Fox Engine Swaparoo 5
R Difference Rear axles Mustang II 1974 - 1978 Mustang II Talk & Tech 7
5 Rear end gear noise 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
6 Budget 1969 mustang rear end build 1965 - 1973 Classic Mustangs -General/Talk- 1
A Finally rear axle being attended too 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 37
Mr.T. Suspension Worn out rear axle Anti wrap shock SN95 4.6L Mustang Tech 0
A Rear axle seal removal and installation 1965 - 1973 Classic Mustangs -General/Talk- 2
J Suspension Rear axles Fox 5.0 Mustang Tech 1
5 3.55 gears for a 87 mustang automatic transmission 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
C For Sale Moser 8.8 Rearend Drivetrain Parts 0
C For Sale Moser 8.8 Complete Rear End Drivetrain Parts 0
Willybill32 Need help with choosing a good rear axle ratio 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 35
S Rear Axle and Stock Fan/Shroud help w/ 351w 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
G Drivetrain Rear axle play/rattle Fox 5.0 Mustang Tech 3
C 1965 with 8" rear end needs axles - How much $$$$$ The Welcome Wagon 0
A Limited Slip Rear End Grinding and Whining 1996 - 2004 SN95 Mustang -General/Talk- 1
ZeroFoxGiven 9in rear end w/disc brakes [Parking Brake] 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
N 1966 mustang rear axle 1965 - 1973 Classic Mustangs -General/Talk- 2
B New Car, New Member, rear axle question. The Welcome Wagon 4
Stangel2001 Swap rear axle 1996 - 2004 SN95 Mustang -General/Talk- 0
2fast4u770 Rear axle 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
G 2011 Mustang Gt 2010 - 2014 Specific Tech 1
Nightstang00 Axles For Rear Cobra Disk Brakes 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23
K Rear End/differential SN95 V6 Mustang Tech 6
B 90 Lsc Rearend In A 89 Fox Lx 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
gruvee87vertgt Rear Axle Seal Part Number? Fox 5.0 Mustang Tech 3
G SOLD 1992 Mustang Rear Axle-complete 5 Lug Drivetrain Parts 0
Josecomputertech 2011 5.0 Stick Shift Rearend 2005 - 2014 S-197 Mustang -General/Talk- 3
86mustanglx Brakes Sn95 Axles In Fox Rear Fox 5.0 Mustang Tech 4
M 1967 Mustang Rear End 1965 - 1973 Classic Mustangs -General/Talk- 3
M 1967 Rear End Classic Mustang Specific Tech 2
NVERL8 Rear Brake Trouble Or Axle Bearing Or ? Classic Mustang Specific Tech 8
M 2002 Mustang Rear Diff Side To Side Slack 1996 - 2004 SN95 Mustang -General/Talk- 1
Jordan Warta Can't Fit Aftermarket Exhaust Tailpipe Over Rear Axle? Fox 5.0 Mustang Tech 3
9 Rear Axle Going Bad? 1996 - 2004 SN95 Mustang -General/Talk- 0
N 88 Lx Rear Axle Damper Rubs New Tire Fox 5.0 Mustang Tech 12
Edbert Rear Axle Brake Lines 1965 - 1973 Classic Mustangs -General/Talk- 0
Ian Ranchero 1967 Rancgero 9" Rear Axle Stuck 1965 - 1973 Classic Mustangs -General/Talk- 2
J Expired Fox Body 1986-1993 8.8" Rear Axle Assembly 3.55 Gears - $190 Drivetrain Parts 1
J Expired Fox Body 1986-1993 8.8" Rear Axle Assembly 3.55 Gears - $190 Drivetrain Parts 0
modulistic 4.6 Swap Underway. Need Ideas To Solve Rear Axle Problem. Fox 5.0 Mustang Tech 31
J Rear Axle 1994 - 1995 Specific Tech 1
J '06 Gt Auto, Rear Axle Noise Help 2005 - 2009 Specific Tech 1
D Progress Thread 1965, 8" Locker Rear Axle Questions 1965 - 1973 Classic Mustangs -General/Talk- 2
8 99 Cobra Rear Axle Question SVT Tech Forum 1
fivespeedsteed Sn95 Rear Axle Swap Questions Fox 5.0 Mustang Tech 44
DetroitSVT Need Help Identifying Rear Axle Issue. SVT Tech Forum 0
