Rear Axle
joebob
my left side axle comes out just a little and the rotor rubs the caliper bracket anyone have an answer for my problemo
  • Sponsors(?)
OldManRiver
112
67
38
46
Central Wisconsin
How much is a little?
Using a dial indicator measure how much axle end play there is.I believe Ford specs out something like .030" as max.If the end play is in the acceptable range shim the caliper bracket to keep it off the rotor.
If the end play is excessive then it's time to install a TracLock rebuild kit to get the clutch pack stack height back into spec,which in turn will tighten up the axle end play.I like to increase my stack height to the tight side so I have less than .005" axle end play,even if I have to lightly tap the cross pin into place.
Good luck
Thread starter Similar threads Forum Replies Date
PonyGTrider Rear axles stability 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 36
BugsOli Drivetrain Passenger side rear axle play and clonk Fox 5.0 Mustang Tech 3
D 1967 Ford 8" Axle 1965 - 1973 Classic Mustangs -General/Talk- 3
E Drivetrain Rear axle gears Fox Engine Swaparoo 5
R Difference Rear axles Mustang II 1974 - 1978 Mustang II Talk & Tech 7
F Drivetrain Rear axle difficult to slide in Fox 5.0 Mustang Tech 4
5 Rear end gear noise 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
6 Budget 1969 mustang rear end build 1965 - 1973 Classic Mustangs -General/Talk- 1
A Finally rear axle being attended too 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 37
Mr.T. Suspension Worn out rear axle Anti wrap shock SN95 4.6L Mustang Tech 0
A Rear axle seal removal and installation 1965 - 1973 Classic Mustangs -General/Talk- 2
J Suspension Rear axles Fox 5.0 Mustang Tech 1
5 3.55 gears for a 87 mustang automatic transmission 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
C For Sale Moser 8.8 Rearend Drivetrain Parts 0
C For Sale Moser 8.8 Complete Rear End Drivetrain Parts 0
Willybill32 Need help with choosing a good rear axle ratio 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 35
S Rear Axle and Stock Fan/Shroud help w/ 351w 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
G Drivetrain Rear axle play/rattle Fox 5.0 Mustang Tech 3
C 1965 with 8" rear end needs axles - How much $$$$$ The Welcome Wagon 0
A Limited Slip Rear End Grinding and Whining 1996 - 2004 SN95 Mustang -General/Talk- 1
ZeroFoxGiven 9in rear end w/disc brakes [Parking Brake] 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
N 1966 mustang rear axle 1965 - 1973 Classic Mustangs -General/Talk- 2
B New Car, New Member, rear axle question. The Welcome Wagon 4
Stangel2001 Swap rear axle 1996 - 2004 SN95 Mustang -General/Talk- 0
2fast4u770 Rear axle 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
G 2011 Mustang Gt 2010 - 2014 Specific Tech 1
Nightstang00 Axles For Rear Cobra Disk Brakes 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23
K Rear End/differential SN95 V6 Mustang Tech 6
B 90 Lsc Rearend In A 89 Fox Lx 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
gruvee87vertgt Rear Axle Seal Part Number? Fox 5.0 Mustang Tech 3
G SOLD 1992 Mustang Rear Axle-complete 5 Lug Drivetrain Parts 0
Josecomputertech 2011 5.0 Stick Shift Rearend 2005 - 2014 S-197 Mustang -General/Talk- 3
86mustanglx Brakes Sn95 Axles In Fox Rear Fox 5.0 Mustang Tech 4
M 1967 Mustang Rear End 1965 - 1973 Classic Mustangs -General/Talk- 3
M 1967 Rear End Classic Mustang Specific Tech 2
NVERL8 Rear Brake Trouble Or Axle Bearing Or ? Classic Mustang Specific Tech 8
M 2002 Mustang Rear Diff Side To Side Slack 1996 - 2004 SN95 Mustang -General/Talk- 1
Jordan Warta Can't Fit Aftermarket Exhaust Tailpipe Over Rear Axle? Fox 5.0 Mustang Tech 3
9 Rear Axle Going Bad? 1996 - 2004 SN95 Mustang -General/Talk- 0
N 88 Lx Rear Axle Damper Rubs New Tire Fox 5.0 Mustang Tech 12
Edbert Rear Axle Brake Lines 1965 - 1973 Classic Mustangs -General/Talk- 0
Ian Ranchero 1967 Rancgero 9" Rear Axle Stuck 1965 - 1973 Classic Mustangs -General/Talk- 2
J Expired Fox Body 1986-1993 8.8" Rear Axle Assembly 3.55 Gears - $190 Drivetrain Parts 1
J Expired Fox Body 1986-1993 8.8" Rear Axle Assembly 3.55 Gears - $190 Drivetrain Parts 0
modulistic 4.6 Swap Underway. Need Ideas To Solve Rear Axle Problem. Fox 5.0 Mustang Tech 31
J '06 Gt Auto, Rear Axle Noise Help 2005 - 2009 Specific Tech 1
D Progress Thread 1965, 8" Locker Rear Axle Questions 1965 - 1973 Classic Mustangs -General/Talk- 2
8 99 Cobra Rear Axle Question SVT Tech Forum 1
fivespeedsteed Sn95 Rear Axle Swap Questions Fox 5.0 Mustang Tech 44
DetroitSVT Need Help Identifying Rear Axle Issue. SVT Tech Forum 0
