rear control arm bushings
  • Thread starter Thread starter pudman
  • Start date Start date Feb 20, 2009
pudman
109
tujunga,ca
Feb 20, 2009
  • Feb 20, 2009
i'm needing to replace all the rear control arm bushings in my 86 gt vert. while shopping online i'm seeing rear lower front bushings offered in round or oval. which ones do i need on a stock 86 suspension? and what is the total number of bushings required for the rear? thankx in advance
Mustang5L5
Mod Dude
Feb 18, 2001
43,314
18,036
224
Massachusetts
Feb 20, 2009
  • Feb 20, 2009
If you look under your car you can easily see. On my '88 they were oval. I beleive the arms are the same.
You have two bushings per arm, and 4 arms total. The uppers are a PITA to do really. Don't go polyurethane in the uppers. Stay with rubber OEM bushings here. Creating too stiff of a setup can lead to snap oversteer.
pudman
109
tujunga,ca
Feb 20, 2009
  • Feb 20, 2009
thanks Mustang5L5. they are oval. that was simple enough to find out, but wasn't sure what i was looking for. i'm new to this car fixing stuff. learned a ton on this forum when i started restoring my car. do you know anything about mevotech stuff? bushing material not as stiff as urethane,but stiffer than rubber. input anyone?
pudman
109
tujunga,ca
Feb 22, 2009
  • Feb 22, 2009
would it be ok to go poly on the lowers?
cenok is family
1,409
69
79
Norman, Ok
Feb 23, 2009
  • Feb 23, 2009
i have UPR tubular uppers and lowers with poly bushings on both ends and i like em. the ride isn't harsh but it is pretty stiff, mostly due to my springs/shocks/struts though. sure does bite a lot harder though.
Mustang5L5
Mod Dude
Feb 18, 2001
43,314
18,036
224
Massachusetts
Feb 23, 2009
  • Feb 23, 2009
Yes.
You just want some "give" on the uppers
Beasty306GT
671
Oxford,Mass
Feb 23, 2009
  • Feb 23, 2009
you should buy a nice new set of uppers and lowers...save yourself a headache just replace them..plus ull have a better ride
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Feb 23, 2009
  • Feb 23, 2009
agreed, the stock stuff is going to flex alot with the bushings, and since they are out you might as well throw a set of nice aftermarket uppers and lowers in it. There are lots of quality brands out there and usually there is something for everyones budget. My advice would be to spend a few extra bucks and buy good stuff, otherwise you will be buying parts twice.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Feb 23, 2009
  • Feb 23, 2009
Your best bet is to get a whole set of control arms instead of keeping the weak stock ones and having crappy rubber bushings. If you don't do any serious drag racing, or racing at all get these.
Uppers:
79-98 UPPER CONTROL ARMS, HEAVY DUTY MUSTANG
My friend has these on this notch and runs 9's!!! They are basically stock replacements with harder than stock rubber bushings.
Lowers:
79-98 LOWER CONTROL ARMS, STEEL <br> MUSTANG
Or get a kit. This will do:
BEST BET...all the way....hands down.
79-98 CONTROL ARM KIT, BOXED, REAR, UPPER & LOWER, BLACK MUSTANG
Mustang5L5
Mod Dude
Feb 18, 2001
43,314
18,036
224
Massachusetts
Feb 23, 2009
#10
  • Feb 23, 2009
  • #10
SVT32VDOHC said:
Uppers:
The steeda arms are the same thing, but boxed and zinc'd and come with poly bushings for the axle and are $99!
I chucked the poly bushings in the trash and bought OEM rubber bushings for the axle. Poly in the uppers is a bad idea.
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
