1995 V6. On RockAuto, it only shows a "rear upper to axle" bushing. My car failed inspection for the rear control arm bushings. How many are there? What are they called? Where can I find them? Anybody know? Thank you!!
So there's no such thing as a rear lower control arm bushing?Rear upper control arm bushings, two, they press into the rear housing, there are also two upper control arms that may need replacing with the bushing already loaded. So there are a total of four bushings.
So the only bushings you can press out and replace are the upper to axle? Sorry to keep asking, I just want to make sure I order the right thing.Yes, there are four of those too. You can get aftermarket lower control arms with bushing loaded
Seriously??
Jesus. Well.. just so you know.. that's not a fun project. You will need a special tool to press them into the pumpkin.. you can buy it on Maximum Motorsports website.. it's basically a giant steel cup that must be then threaded and you take a 1/2" ratchet and tighten them in... that's if you know how to get them out to begin with.. which can be even trickier.. or you can just take a sawzall to them and cut them out.. just be careful lol.
I've done it a few times, have the tool, and wouldn't ever bother trying again without that $50 tool, or whatever it cost these days. Also, NEVER buy poly upper bushings. ALWAYS replace with factory rubber.
I am kind of lazy and would purchase new aftermarket control arms with the bushings already installed....
I have had serious difficulties with MAC control arm bushings in the past. They would fall apart inside the control arm. The end result would be a steel sleeve inside the control arm housing bouncing around. Anyone else experience these turds? I have a new set and i am afraid to install them with those junk bushings.....Long story research bushings and control arms before replacing them if you go aftermarket.
He is talking about the bushings that press into the upper portion of the rear end.
And yes.. MAC is trash.. lol. Stick to Max Motorsports or Griggs or Team Z.
. I mean it was still
, but they produced results, and we would all deal with the hassle of their trash bushings to get results. Mac is stuck in the past, and hasn't updated anything they sell in a quarter century. It's sad they they are able to still sell stuff on the name they built over 2 decades ago.Its been awhile seen replacing control arms. I knew he was referring to the bushings in the axle, but wanted to chime in on replacing the other bushings as well. It is such a miserable job for me to replace control arms. Maybe my poor attitude is due to lack luster bushings and multiple replacement jobs on the same car?? My thoughts if one is bad the others probably are not too far behind. I would replace all the bushings while its out and maybe upgrade to new control arms.
I am really sad the mac control arm bushings a junk. I had a lot of faith in the brand.
as before, and people still look at the name and think "oh, it's steeda".. or whatever.. and it's crap..
companies are even still in business.. yikes..
