Rear control arms
Cantslowdown said:
Is the FRPP just as good as the rest of them?
I have the FRPP ones. I dont have them on yet so I cant help you out. From what I heard there not bad at all. I got a good deal on them so I got them. Either those, MM or steea would be the ones to get.
Cobra Jet R said:
I just got adjustable MM LCA and Ford's UCA installed last week and they feel great. Was also able to lower the rear a bit as it sits higher in the rear. Is FFRP the same as Ford Motorsports?
you should play with the adjustable control arms to adjust ride height. this messes with your pinion angle. double check you pinion angle.
