rear discs!........stock 8in?
mean78
89
ok so i was just wondering if anyone offers a kit for rear disc brakes on a 8in?
and if not, what is the popular way of doing this? (assuming people have)
Ministock racers use escort rotors and gm metric calipers. They are not concerned with parking brakes so its a pretty simple job.
Well this says it'll work, and it'll hook up parking brake.
http://www.stainlesssteelbrakes.com/products/detail/2383/?make=Ford&model=Mustang+II&year=
I really can't go farthur than that, never used it... hell I haven't seen my car in 3 years, I just happened to run across it last week.
There is a link so see the dimensions of the axle flange on that page.
And then you'll need a proportioning valve and maybe a new master cylinder.
But once you get everything worked out, you should do a little write up for the rest of us...
I used the TSM's on my Cobra. Seville Calipers, but when I bought it nothing else was available. Calipers bolt up nicely to the brackets. I added one inch to the emergency brake bracket and the II cables fit perfectly. The bleeder screws don't end up verticle, so I've either gravity bled them or used a pressurized bleeding system from the master cylinder, doing this requires them to be laying on the leaf springs with the bleeder screw upright. No brake pedal bleeding.
Currie offers an 8 inch kit using the later model red Cobra calipers.
Dave
