rear end questions
ok so my currie 9" housing should be here tomorrow (HURRAY!!!) but i was looking at my current rear end tonight, and then a few questions suddenly dawned on me.....
Q1. Am i going to need to get different spring pads?(or whatever those things are called that the shocks and u-bolts bolt into.) If so, are there any that might come from a different car that will fit?
Q2. I ordered the axle housing and 31 spline axles without a 3rd member (trying to save some cash). Is anyone aware of a stock application that used a 9" 31 spline trac loc rear? I'm hopefully going to be hitting up a junk yard this saturday to get the rest of the stuff i need to finish the conversion.
Oh yeah...
Q3. When you switch to the 9", do you need to have the drive shaft shortened?
i highly doubt you will find a 31 spline third member since they only came in very few cars (cobra jets, boss).i have a few third members, all you would need a 31 spline diff. i have 3.10s and 4.11s
The best source for a trac lok with 31 spline axles is a pickup truck, van or a Bronco. You can tell by the axle code on the door if it is a trac loc or not. That is if is the original axle carrier.
New spring plates and U-bolts are going to depend on if they put the smaller axle tubes on the end or not. If they did it right for your car it should have the small tubes and you can reuse your spring plates and U-bolts. If it has the larger tubes (there are different O D large tubes also) you'll have to get new U-bolts and spring plates. You can drill your old plates out to match the wider tubes though. I welded mine up and then drilled them so it wouldn't have an oval hole in it. I haven't got to the driveshaft part yet but it is my understanding that there are two different yoke lengths and the driveshaft has to be shortened for both. I'm going to try a short yoke first. There are people on here that have completed this mod so maybe they'll chime in and give you more info.
You can have the large tube and small bearing 31 spline axles, thats what I have. You can keep your stock drive shaft if you use the short passenger car yoke, you will need to change the rear ujoint, it will now be the same as the front ujoint.
Spring plates from a 67-70 will work..NOT the ones for a stagger shock...
The ends i have are the Torino style big bearing ends. I also bought some baer brakes to match, so it should be ok. I'm just down to getting a 3rd member. Does anyone know how much better a detroit tru-trac is compared to the ford trac-lock? I know someone who can get me a good deal on one, so i'm a little tempted.
Elroy said:
Be aware that if you do find a 31 spline axle from a truck it "MAY" actually be a 9 3/8 NOT a 9. Check it out before you buy it
I've looked at a lot of truck rears and only one had the 9 3/8. Most of the 9 3/8's that I have saw were in station wagons and big cars. I would make sure that it wasn't the wrong carrier though.
