Rear End Refreshning Questions
squares98
852
Orange,ca
I need to replace my carrier and pinion bearings(at least probably) cause of the rear noises associated. My question is, should I have them replace the stock 28 spline axels with a stronger 28 spline ones. Which brand?
I think you meant should you replace the stock 28 spline with 31 spline...
That is a tough decision which only you can make. It depends a lot on your plans/goals for the car.
BUT while your rear-end is being worked on have the axle tubes welded and the exterior painted with a paint that goes right over rusty metal :nice:
