First step is to not move around the thing like a programmed android, but use your head and think your way through each step
~Put the cars frame on jackstands and then put the tranny in neutral with the e-brake off once in the air.
~Disconnect the 4 driveline bolts and slide the driveline out of the back of the transmission.
~Put on the e-brake and place tranny in gear.
~Loosen the lug nuts and pull off the wheels.
~Put the tranny back in neutral with the e-brake off again.
~Unbolt any brake lines or cables that are attached to the axle and brake assembly as needed (use your common sense here)
~Place two jackstands under the axle tubes on the rear end in a spot free from obstructing your work.
~Remove the 4 sway bar bolts (2 ea side) and remove sway bar that is bolted to the "lower control arms" (lca)
~Remove all 4 shocks (2 are small and run horizontally)
~Place a good, strong floor jack under the lower control arm where it mounts to the "rear end" (diff) axle tubes.
~(This is where spring load comes in to play) Remove the bolt that connects the lower arm to the diff
~Slowly lower the jack to release the spring tension and then pull the spring outta the way.
~Remove the other sides spring now in the same fashion.
~Remove the "upper control arm" (uca) bolts and take out the 2 uca
~Pull out the diff making sure you disconnected the brake lines and e-brake cables as necessary ...
