As the title states I need serious help with my rear gear setup. I am putting 3.73 used gears in an 8.8 with all new bearings and seals with a rebuilt trac-loc. I measured both setups and my new pinion bearing was taller than the origional, of which had been disassembled prior to me getting it, so I needed a thinner pinion shim. I measured twice pressed once and came up with a wear pattern on the upper quarter of the heel of the coast side and the lower quarter of the toe of the drive side. Which by several different sources found online indicates I need a thinner pinion shim. I have since made three shim changes and the pattern persists. I started with a .022 shim and I am currently at a .012 with little change in the pattern. Help someone please help as I have to rap this up tomorrow. I tried to take pics but couldn't get a decent focus.
