  • SN95 4.6L Mustang Tech
Rear end strength?
  • Thread starter Thread starter MustGeeTee
  • Start date Start date Aug 1, 2005
M
MustGeeTee
  • Aug 1, 2005
How well can our rear end handle MT ET streets (drag radials)
hotrodnut
672
North Florida
Aug 2, 2005
  • Aug 2, 2005
Stock? Not very well, the weakest part is the axles, some will say they have used stock parts for years without breakage when using drag radials/slicks but trust me, more will say their's broke.
Best bet is to invest in some 31 spline axles and a good posi, then you can be assured your chances of ripping something out of the rear is minimized.
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Aug 2, 2005
  • Aug 2, 2005
Just so you don't have to ask, yes, a 31 spline set of axles must be paired with a matching 31 spline rear differential. Also, the typical cost for a set of 31 spline axles and matching differential will run about 500 dollars, perhaps as much as 600. Depends on what brand you go with. Moser is a good brand as is FRPP. Some good places to check for parts are the following:
www.gefracing.com
www.stangstore.com
www.mustangtuning.com
www.modulardepot.com
Another good guy to go with is Randy Stinchcomb out of Liberty Ford in Maryland. He can be contacted at Modular Depot in the link I listed above in the Ford parts section of their forums board.
I see you don't have any aftermarket gears listed in your current mods in your signature. It would probably be best to upgrade your axles and differential to a 31 spline setup when you decide to do a gear swap. This way, it all gets done at once. Thats what I did and it worked out great.
J
Joel's98GT
368
central OH
Aug 2, 2005
  • Aug 2, 2005
like said above, stock = NO.
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
