Rear End Troubles
  • Thread starter Thread starter PerformanceRed94GT
  • Start date Start date Feb 5, 2017
PerformanceRed94GT
West Virginia
Feb 5, 2017
  • Feb 5, 2017
Okay guys I'm in need of some help . My 94 sn95 has the 8.8 rear end . I checked all my gear in the diff and every thing is perfect with no wear . When I turn sharp I get a loud clank noise from the passenger side rear . If I'm in third gear rolling and drop it to second and smash it to run someone I get a very loud pop noise from the rear . I'm in need of help bad lol .
Mustang5L5
Mod Dude
Feb 18, 2001
43,376
18,123
224
Massachusetts
Feb 5, 2017
  • Feb 5, 2017
Gonna have to pull the wheels off, pop the cover off and have a look. Could also be suspension issues and bad bushings. Really need to look at the car to determine the cause
Reactions: Davedacarpainter
Davedacarpainter
SN Certified Technician
Nov 28, 2015
11,833
11,634
203
Discordia
Feb 5, 2017
  • Feb 5, 2017
The loud pop noise makes me think more towards the suspension than the gears.
General karthief
Mod Dude
Aug 25, 2016
28,134
10,752
213
polk county florida
Feb 5, 2017
  • Feb 5, 2017
I'm inclined to agree. Jack it up by the rearend housing just enough to get the wheels off the ground an shake the body side to side, then try it with the tires sitting on something like ramps or blocks, also try shaking the rear end at full drop, you may find a shock bushing, control arm bushing or loose sway bar. Maybe even a tail pipe loose or a prius stuck under there.
Reactions: Boosted92LX
Dan02gt
mazing how much gas smell came from that tiny hole
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
Feb 5, 2017
  • Feb 5, 2017
I would be willing to bet the control arm bolts are loose. Try tightening up everything.
billison
I like tinted tail
2,607
1,094
184
stl
Feb 6, 2017
  • Feb 6, 2017
Sounds like bushings orsomething loose
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Differential noise over bumps
  • sharkrat
  • Apr 10, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 18, 2026
TPony
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
Rear ends? And I don't mean the pretty kind.
  • WORTH
  • Jun 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 14, 2025
limp
