Rear End Woes
  • Thread starter Thread starter Brody1
  • Start date Start date Aug 6, 2007
Brody1
20
  • Aug 6, 2007
After investing over $1000 in labor and new parts (ring & pinion, all bearings, axles, clutch discs in differential) on a rear-end rebuild it whines like howling dog. It was in the shop for over a month because the mechanic (trusted & qualified) had to tear it down several times to try to quiet it down with no success. I am now being told that my rear axle housing is bent which is why it can't be aligned properly. Apparently this car took a lick to the left side (evidence of body work) that I was unaware of when I purchased the vehicle (clean CARFAX). My options now are to purchase a used complete rear end assembly from a local salvage yard for $700 or purchase a new empty rear axle housing from Ford for $750 and have all my new parts installed in it. Has anyone had experience with changing out the entire rear axle, and which option would you go for? I'm going to have to do one or the other because I can't live with the whine.
Brody
Shamus O'toole
18
Florida
Aug 6, 2007
  • Aug 6, 2007
Before you go through all that what kind of gears? and what ratio?
Brody1
20
  • Aug 6, 2007
Rear Gears
I specified I wanted only Ford Motorsport 3:73 gears. Hopefully that is what he ordered.
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Aug 6, 2007
  • Aug 6, 2007
try to find a used axle housing on a classified or something.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Aug 6, 2007
  • Aug 6, 2007
where are u located?
merc123
420
North GA
Aug 6, 2007
  • Aug 6, 2007
$700 is unreal for a used rear end considering you can get a new housing and all aftermarket parts cheaper than $1400....
Brody1
20
  • Aug 7, 2007
Rear End Woes Cont'd
I'm located in N. Alabama. Genuine Ford Parts out of Sherman Texas wanted $571 for a bare housing plus $170 to ship. The used housing is complete our of a 99 GT. I already have all new parts to go in it. I did find out that the ring & pinion the mechanic purchased for me were not Ford Racing but a company called "speedmotor" whom he claims makes the gears for Ford Racing. I could not find any proof of that so I have personally ordered the Ford Racing gears to put in when he rebuilds the used housing I have now purchased. I did also find a complete rear axle assembly out of a 03 Centennial Coupe in Georgia that would have run me $950 delivered. I'm committed now (or should be) to using this housing out of a 99 GT. I'll let y'all know how it works out.
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
R
8.8 rear end for '67 coupe, shortened - next steps
  • rubendenver
  • Dec 15, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jan 8, 2025
GOvert
G
