rear main-leak
  • Thread starter Thread starter NormD
  • Start date Start date Jul 28, 2007
N
NormD
27
  • Jul 28, 2007
I just started my 351W which was built last year. It runs fine but there is a small oil leak I suspect is the rear main. Perhaps the seal dried up? My question: does anyone recommend any oil additive to swell the rear main and stop the leak?
Thanks, Norm
C
chromedog
554
worlds center for speed
Jul 28, 2007
  • Jul 28, 2007
im chasing the same demon you are, only the rear seal in question is new...one question... what year block do you have? mine is an 85, which uses a one piece seal. does yours leak down onto the bell housing, then onto the ground? or is it around the pan rail. IF it turns out to be a pan gasket, do yourself a favor, spend the extra bucks, and get the one piece pan gasket... that way, you have one (actually three) less places for the oil to leak from. as far as the leak stop question, that stuff is basically lacquer thinner, it might work for a while, but i feel it would make all the seals brittle over time, and instead of replacing the rear main, you are replacing all the seals in your engine.
N
NormD
27
  • Jul 29, 2007
My block is a 1973 block. It leaks (slightly) down onto the bell housing to the ground. Thanks for the advice on STOP LEAK ADDITIVES. I think since it only has run about 30 minutes i will wait and see if it "heals" and if not then replace the seal. Have you replaced these seals while still in the car and if so what tips can you offer....................thanks.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
Engine Oil leaking
  • greenflash79
  • Apr 1, 2026
  • 2007 - 2014 Shelby GT500 Tech
2007 - 2014 Shelby GT500 Tech Apr 6, 2026
greenflash79
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
