rear main seal install
  • Thread starter Thread starter speedy66
  • Start date Start date Jan 4, 2004
speedy66
629
glendale,arizona,usa
Jan 4, 2004
  • Jan 4, 2004
87 roller block. need to install a rear main seal on it.. how is the best way to do it.. The manual shows a tool but havent been able to find it. any suggestions
thegabrielles
516
Atlanta Georgia
Jan 4, 2004
  • Jan 4, 2004
Well obviously you know the tranny clutch and flywheel need to be removed. I have installed them with just a lot of patirnce and a hammer with a wooden block. The best way to do it is to have something that fits the size of the seal and tap it in lightly. Dont ever force it. If you get it going in straight it will have some resistance but will move in with every hit.
Go easy and use patience other wise you will be redoing it in a couple of months. I think Autozone might have an iostallation tool you can "borrow"
speedy66
629
Jan 5, 2004
  • Jan 5, 2004
Ok thanks.. I will try autozone..
Its a new motor im building.. so its on a stand right now.. so clutch is no problem
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Jan 5, 2004
  • Jan 5, 2004
also if you're around a Pep Boys they rent out tools as well for a deposite, which i believe you get back when you return the tool.
9
93-ex-chp
96
  • Jan 5, 2004
I was able to use the old seal reversed to tap the new one in without issues.
LXMiker
159
Good ol' Wisconsin
Jan 5, 2004
  • Jan 5, 2004
if you need to remove the old seal a trick is to drill a screw in a little ways and pull on the screw you may need to do this in a couple of places around the seal
then use the old seal to place the new seal in the block......
blksn955.o
3,263
st.louis mo 314
Jan 5, 2004
  • Jan 5, 2004
I just took my time and with a small flat screw driver worked it out and used the old one (with the flat side to the flat showing side of the new seal) to drive the new one in. I placed the old seal on the new one and tapped it with a hammer very lightly until the new seal was in the correct amount.
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
