  • SN95 4.6L Mustang Tech
rear output seal
  • Thread starter Thread starter streetstang03
  • Start date Start date Dec 9, 2004
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Dec 9, 2004
  • Dec 9, 2004
How hard is it to replace the rear output seal on the tranny? my car is leaking tranny fluid from the ROS and if its not to hard to fix, i may do it myself. What tools are needed and whats the level of difficulty? Im estimating at least 3 hrs to do the job.
billyfe390
573
  • Dec 9, 2004
A hammer, chisel and about 20 minutes of your time if you can get the driveshaft bolts out. Take the driveshaft out obviousely and then either take a screwdriver or prybar and hook under the inside lip and pry it out or take the chisel and chisel up the outside lip and then pry it out. Clean everything and gently tap the new one in making sure it goes in square.
The hardest part may be the driveshaft bolts. They are factory loctited and usuall dont come loose without heat.
streetstang03
unModerator
Dec 27, 2003
Dec 10, 2004
  • Dec 10, 2004
bippity boppity BUMP!!!
billyfe390
573
  • Dec 10, 2004
What else do you need to know?
Its not that hard.
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
M
Drivetrain T5 Transmission Leak at Tailshaft
  • MDrisc
  • Jun 17, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
AeroCoupe
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Monday at 4:00 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 9:11 PM
2000xp8
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
