hey....after talking with my father today were going to put in my gears next sunday....i know that i've asked these questions before.....but all i'm going to install just the gears....is there something i need to know before i begin???? what tools will i need???
its opened up and its cheap to replace the rear ends...trac loc rebuilds are like 45 bucks.... then get a rear end mini kit it comes with your crush sleves and pinion seal and shims and what not....make sure you also get a bottle of friction modifier to add to the fresh gear lube...
also when you remove the rear calipers be sure to use C clamps to keep them compressed while you are doing the work or you will have to buy the tool to recompress them. A floor jack and jack stands are a must have also, a hand pump to put the gear oil sure helps alot too. Be patient and measure everything 3 times before putting it back together and you've got a good chance of it turning out okay. The link below is what I used to install mine and I'm still rollin' 4000 miles later. Good luck and if you have any more questions just ask.
