Rear Shocks
  • Thread starter Thread starter Tooncis
  • Start date Start date Feb 24, 2004
Tooncis
1,221
San Antonio Tx. USA
Feb 24, 2004
  • Feb 24, 2004
Where can I find coil over spring shocks to fit a 65 Stang?
Thanks
A
ARTTII
272
Detroit, MI
Feb 26, 2004
  • Feb 26, 2004
Thanks
What exactly do you mean by 'coil over'?
Sorry I'm no help but maybe this will get you off the third page and an answer!
Pakrat
3,843
Currently: NH Originally: Rhode Island (and all po
Feb 26, 2004
  • Feb 26, 2004
Wait a second, that question was totally clear and precise with perfect formatting. Not the least bit psychotic at all. Are you sure you're the real Tooncis?
bnickel
5,640
lubbock, texas
Feb 27, 2004
  • Feb 27, 2004
if you are talking about the rear shocks with the coil springs mounted to them to use in place of your regular shocks and still using the leaf spring rear suspension, monroe sells them, they are the load leveler series shocks, they were about 65 bucks for the pair last time i checked, if you can't find a set locally let me know, i still have pretty connections from being in the parts business fro several years and i think i can get you hooked up with a set, although probabaly won't be cheap, those things are heavy
Route666
1,652
Brisbane, Australia
Feb 27, 2004
  • Feb 27, 2004
Here's the obvious, and I love how the similarities. TCP is to mustangs as Dillon Reloaders are to shooting. Both may not be the best (but are good quality, no one can dispute) but they are the most well know and used. (Well, maybe TCP isn't the most used, but considering most people probably don't reload, I'd say the proportion is appropriate).
Anyways, TCP have a real coil-over system. Not only that, but the rear suspension setup they have has a much lower centre of gravity than stock suspension, and has allowances for (the necessary in my opinion) torque arm. 5 grand though...
Anyways,
bnickel
5,640
lubbock, texas
Feb 27, 2004
  • Feb 27, 2004
not even a comparison between the 2, the load levelers are a shock with a helper spring, they are most commonly used for towing or where a large amount of cargo is carried in the back, they are sold for just about any car you can think of and they are also used failty often to pick up the back end of a car that has sagging rear springs, which i think may be the reason he was asking about them, i could be wrong though
Pakrat
3,843
Feb 27, 2004
  • Feb 27, 2004
So then if you are correct about the reason, would a more direct and readily available comparison be an adjustable air shock then?
bnickel
5,640
lubbock, texas
Feb 28, 2004
  • Feb 28, 2004
yes pak you would be correct
Pakrat
3,843
Mar 1, 2004
  • Mar 1, 2004
Wow, there really is a first time for everything.
Now if Tooncis (or the refined person posing as tooncis) would chime in again, we might just figure out what he's after.
bnickel
5,640
lubbock, texas
Mar 1, 2004
#10
  • Mar 1, 2004
  • #10
hehe, jeez pak you're at leats a few years older than me, and these things have been around longer than i have, i was sure an old codger like yourself would have heard of them, LOL i'll see if i can find a pic of them on monore's website, tune in next time, hehehe
bnickel
5,640
lubbock, texas
Mar 1, 2004
#11
  • Mar 1, 2004
  • #11
here is a link to moroe's website, it's hard to tell in the pic, but there is a coil spring around the shock.i'll keep looking and see if i can find a better pic somewhere
http://www.monroe.com/products/mp_detail.asp?cat=Sensa-Trac&detail=Load Adjusting Shock Absorbers
bnickel
5,640
lubbock, texas
Mar 1, 2004
#12
  • Mar 1, 2004
  • #12
well i tried autozone and advance websites and they don't have any pics of them but they do stock them, i wish i had gone with those instead of the airshocks i ran when i was young and stupid, would've prevented a huge hole in the rear shock tower (body mount) that still isn't really fixed right but it works, so i think i'll just leave it alone for now, like i said it works, it's just ugly but you can't really see it unless you're under the car, so.................
Pakrat
3,843
Mar 2, 2004
#13
  • Mar 2, 2004
  • #13
Hey now, I'm one year older at best, ok maybe a year and a month, but that's it. Honestly never heard of them though. When I first started to appreciate Muscle cars it was in high school, mid eighties, and everyone was going with the big shackle look back then. Plus I never was much for being stupid even while I was young where quality was concerned, (acted stupid plenty of times though and did plenty of stupid things) if I needed new leafs I got new leafs, not a band aid. I'll bet I have seen them, and just didn't notice or never really gave them a second look.
So I'm curious, how would these have helped differently to not cause a hole in the shock tower than the air shocks did? I have still left the air shocks on the back of my car from the previous owner. They are normally almost dry, but back in the day before my garage, when I had to keep all my tools in the trunk, I used to pump them up a tad. Now I'm nervous though.
bnickel
5,640
lubbock, texas
Mar 3, 2004
#14
  • Mar 3, 2004
  • #14
it was more a problem of having the air shocks pumped up almost all the way and driving a friend home down a washboarded dirt road that did it, the springs on the load leveler's will give whereas the air shocks didn't. but still i wouldn't run air shocks if i were you, if you don't need the tire clearance and don't carry anything heavy in it you should be fine with a good gas shock on the back, if you still want a soft ride try the kyb gr2's i heard they are a really decent shock for the money. as far as having to run the air shocks i needed tire clearance and couldn't afford new leafs at the time, after i blew out the tower i had a front strut bushing washer welded in place and then installed those stupid shackles that i didn't want to put on in the first place which is why i went with the air shocks, but hey you live and you learn, right? but now i have a set of 5-leaf mid-eyes waiting in to go in when i get the versailles rear finished and ready to go in, along with some 295/50-15's. and stock shackles with midolyne bushings. i may have to get some of the adjustable "racing" shackles from mustang plus or american pony IF i need the extra clearance but i don't think i will, but i might not have the rake i want either, so we'll see, i'll let everyone know when i get it done, and hopefully i will have a new digi-cam bby then so i can actually get some pics of the beast posted up
Pakrat
3,843
Mar 3, 2004
#15
  • Mar 3, 2004
  • #15
OK, I got ya. Yeah, I have been wanting to put some KYB's all around, I just haven't gotten to it. I have a hard time getting myself to replace things that aren't broken when I have broken things to repalce first, ya know. Maybe I'll just do it this year though, I sure don't want any bigger issues to arise.
allcarfan
The Answer Man
2,458
North Atlanta
Mar 3, 2004
#16
  • Mar 3, 2004
  • #16
This thread has been officially highjacked
Pakrat
3,843
Mar 3, 2004
#17
  • Mar 3, 2004
  • #17
Blame it on Toonics for the hit and run thread.
It never fails, when someone asks a question that help replies to right away, the person seems to disappear, and when someone is impatient and TTT's it every hour, no one answers.
bnickel
5,640
lubbock, texas
Mar 3, 2004
#18
  • Mar 3, 2004
  • #18
yeah pak, i'd say ditch the air shocks as soon as possible, but if you don't put much air in them anyway i wouldn't make it a big rush
Tooncis
1,221
San Antonio Tx. USA
Mar 4, 2004
#19
  • Mar 4, 2004
  • #19
Psychotic Tooncis!
This is the real tooncis-to reasure you guys this is psychotic-I inherited a 1971 MGB wich I'm also restoring it's almost done & on the road. I also have a 1958 Morris Minor I'm doing next.
My Stang has the KYB rear shocks & I installed bolt on springs on them it's working fine & no fender rub on hard bumps I just wanted something more reliable. I work at auto zone now (IT field is dead).
My Stang is really running good
Good to hear from everyone!
Thanks!
Tooncis
1,221
San Antonio Tx. USA
Mar 4, 2004
#20
  • Mar 4, 2004
  • #20
SHOCKS
My account was paused for e-mail update & I couldnt reply.
If some of you remember my differential is 1" longer on doth sides & I have 15" tires -when I hit a bump my fenders would chomp on my tire sides.
I'm using KYB with some add on springs. this arrangements works really good
but I'm not sure if the bolt on assist springs are reliable. anyone ever use these? There from auto zone.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
D
Hey Ya'll from the North Georgia mountains
  • dulcimerbob
  • Sep 11, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 12, 2026
General karthief
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Suspension Quad shocks
  • keel
  • May 20, 2026
Fox 5.0 Mustang Tech Sep 2, 2026
AeroCoupe
