Rear Suspention questions
  • Thread starter Thread starter 93tsiawd
  • Start date Start date Nov 28, 2010
9
93tsiawd
34
South Jersey
Nov 28, 2010
  • Nov 28, 2010
Ok The stock bushing and springs and struts are trashed. So I Wanted to get a few idea's before buying a kit or parts. I have done some reading and what Im trying to accomplish here is.... DOT's Tires not spinng at 5k launch then hook and the nose not droping 10 foot past the line and start breaking the back tires loose and the car steering itself on the long side of the track. lol i needs help it does everything its not suposed to.
I think Im going to do the eibach drag springs for the rear, southside bars or traction bars that are close to equal. adjustable uppers so I can dial them in at the track and all poly bushings. not sure on the struts yet. also got my buddie fabing up some sub frame conectors and beefing up the battle boxes. also it is a vert.
for the front I was going to leave stock springs and go with some lakewoods coil overs adjustable and the billet mount on top
I am also goin to do my inner tie rods and have it aligned but I think Its the rear steering on me at high speeds and the front end bouncing up and down.
please some construtive critisim would be awesome, trying to slow up the rebound ratein the front and stop the ass from dropping off the line
7upstang91
936
124
74
Florida
Nov 29, 2010
  • Nov 29, 2010
Strange Adjustable. Or Qa1s
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Nov 29, 2010
  • Nov 29, 2010
are you talking a true DOT street tire or a drag radial DOT tire?
T
t76stang1Day
62
Providence, RI
Nov 29, 2010
  • Nov 29, 2010
Maximum motorsports rear LCA's and panhard bar should fix that rearend for ya, and as for dampers i run koni on my car. there adjustable, very great for coil over setups, and they are lifetime warrenteed
9
93tsiawd
34
South Jersey
Nov 30, 2010
  • Nov 30, 2010
found some lca's
Found some, southside LCA's I read up about how they kill the battle boxes because the dont have any poly in the bushings?
has anyone had these problems?
or beefed up the battle boxs good enough?
My buddie is a welder/Fabricator who is also into Foxbodys, He thinks we can reinfoce them good enough.
also Most of the time it will be on street tires, I need a set of rims to mount my M/T Dot slicks for those weekend night street runs.
N
njoliver
259
Columbus OH
Dec 1, 2010
  • Dec 1, 2010
I think you can make the battle boxes strong enough to hold up. weld them good and putting reinforcement in them makes them pretty strong
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
