Rear window problems.............
mustangfiveo198
145
Driving my STANG
On both of my rear power windows in my 89 vert, the motor has power to it, but the windows don't go up or down. I took off 1 motor to check it out and when I pressed the down/up switch the motor was spinning the sprocket but it had alot of slips in it. Like it would stop alittle, be normal speed, like something was slipping inside the gears. So my question is, since the motor sounds like it is working fine, is there anything else that would be a problem? Maybe the sproket itself???? I don't know. Also if I have to buy new motors where do I get one and what price.
Any and ALL info would be great.
Thanks alot.
Thanks alot.
You can replace the bushings in these motors, thats probably your problem.
It takes 1 minute to open it up - The race that holds the gears is probably cracked. I need to find those myself so I can rebuild my old ones.
Mine would also spin ok on the bench but didnt have the torque to move the window.
Good luck.
Still looking for some more info on this. I have the entire rear driver side seat/window apart. The motor seems to work fine, but something is making it not engage.
Do I need new bushings or something?
I need some help.......manual page, diagram, website..........anything.
Thanks again!!!
Did you ever open the window motor up? It's real simple inside (I just had one open two weeks ago - I was speaking from experience about the window motors). There's a couple of small fasteners and that's it. I still think you'll find a busted bushing or race inside (my race was cracked in about 20 places). So with the motor not connected to the regulator, it would spin fine ("Gee, the motor works good."). But as soon as you load the output shaft, rather than transferring torque to the window regulator, the race would pry itself apart (kinda like a hernia inside the window motor).
If you really get stuck, I can try and take some pics of the inside of one of my window motors (I got two used ones that work so I can rebuild my old ones once I can find the race).
I really think you'll find the inside (all plastic crap gears and parts) to be the source of issue.
FWIW on my 88, I can pull the plastic panel out and do this stuff with the seat in place. You gotta mess with it but it works.
Good luck.
