Rear Window Weatherstrip Replacement Help
BLKsteeda
236
Anywhere
Has anyone replace the piece of rubber weather stripping that runs along the base of the rear window between the decklid on a 99+ Mustang? Mine is stained severly and I found a replacement piece but I'm told it requires the window to be removed, is this correct???
Thanks for any info
I'm tempted just to buy a new one and yank off the old one to see what happens...the old one will literally slide right off. I have a friend at Ford that is checking with his techs as well as in his manual to see if requires removal of the glass. The only part that looks tricky is on the ends
Mine is the same way. Let us know if you can do it without removing the window. If so, I'm jumping all over that. Looks like crap right now.
Where did you get the replacement and what did it cost?
