I have a 89 ford ranger 4x4 and does anyone know what gears are in it and will it bolt up to a 88 mustang? I dont think it will but I'd figured I'd see what you guys think..
stangbear427 said:Or even better, a Tbird Supercoupe 8.8 with the rear discs...
Not that they're the same bolt pattern, but 7.5-inch and 8.8-inch axles are interchangeable and will work with either gear set. The only problem being that only the left axle is the same length.BlackFox5.0 said:Rangers have 7.5" axles, and the pumpkin is offset, same for the Aerostars, only the pumpkin is offset to the opposite side than the ranger.
Gearbanger 101 said:If it's from 2.3, 2.9, or 3.0L Ranger, then it will have a 7.5 inch rear end. If it’s a 4.0L (which debut in '89) is has the same 8.8 inch rear end that our Mustangs have. Unfortunately, only the gears and left axle (if you were doing a 5-lug conversion) are of any use.
You're right Matt, but read it again, that's not what I said! You must have missed this part.....Matt90GT said:No, the 4L Ranger does not use the same 8.8 axle housing as the mustang.
The pumpkin in the rangers is offset by about 1" from center. The mustang is centered. The mustang uses the 4 link, Ranger leaf springs.
Gearbanger 101 said:You're right Matt, but read it again, that's not what I said! You must have missed this part.....
