Rearend Help
  • Thread starter Thread starter marine_2003
  • Start date Start date Oct 24, 2005
marine_2003
427
Lake County, FL
Oct 24, 2005
  • Oct 24, 2005
After wrestling with the seals in my rear axle for about 15 minutes they finally came out, the seals or the bearings havent been changed in 15 years. Does anyone know how to get the bearings out without taking the axle tube off?
Thanks
jackchan
507
Mobile Alabama
Oct 24, 2005
  • Oct 24, 2005
which bearings.? axle bearings?
jack
marine_2003
427
Lake County, FL
Oct 24, 2005
  • Oct 24, 2005
The bearings that are right ehing the seals after you pull the axles.
M
mustang-a-holic
51
  • Oct 24, 2005
1. take a screwdriver and pull the cage apart, remove the rollers.
2. Use a bearing puller and grip the race. Hammer away. Another method is to use a long piece of conduit and push the race out from the opposite tube. (Cleaver....not sure where I got that one from, but it's stuck with me for years.)
3. Clean out bearing surfaces, install new bearings, seals
4. Crack open a cold one and admire your work.
jackchan
507
Mobile Alabama
Oct 24, 2005
  • Oct 24, 2005
same thing we use to do. But we used a solid still barstock rod. Works great I might add!
Jack
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
9
1994 Mustang GT 5.0 L Convertible
  • 94ns95
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2026
94ns95
9
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
