  • SN95 4.6L Mustang Tech
Rearend Noise?
  • Thread starter Thread starter ImportEater98
  • Start date Start date Jul 18, 2004
ImportEater98
708
Worcester, MA
Jul 18, 2004
  • Jul 18, 2004
Hey there....I did a search to find threads on this and i still can't seem to find the answer i am looking for. My GF just bought a 2000 GT 'vert 5 Speed. When taking a sharp corner (or driving in circles in a parking lot) left or right, we get a sort of moan/squeek consistant with the tire's RPM. After doing my homework, i figure its the TracLock (aka Posi Unit) that is no good. Is this something that is just going to make noise for the rest of the car's life, or is it eventually going to give us big problems? I am in a "catch 22" position. We bought the car used, and it has a warrenty (its not from a ford dealer, from a used car lot), but i dont' want the in-house mechanic at this dealer opening up the rearend. Its a very delicate thing to play with as most of you know, and i would much rather have a Ford tech (or a rearend specialist) do the work. What do i do?
trinity_gt
3,125
81
99
Canada
Jul 18, 2004
  • Jul 18, 2004
You might try first changing the fluid and ensuring the Ford friction modifier (required by the diff) is put in.
The only big problem I'd see are a possible loss of the LSD function; a bad Traction-Lok might make noise and result in one-wheel-peels but I doubt it would stop you from getting where you're going.
ImportEater98
708
Worcester, MA
Jul 18, 2004
  • Jul 18, 2004
Well i guess i should have the dealer try that first. That is probably what they will have planned to do. Start cheap and work thier way up if the problem persists. Thanks for the info! Anyone else that can add to this?
TopDeadCenter
109
  • Jul 18, 2004
not to let u down..my rear did the exact same thing..and it blew last night...started knocking..squeeling..big pain..thank god for warranties by the way mine was the fuel pump
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
D
97 V6 suspension upgrades
  • Dale1bre
  • Jan 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jan 19, 2026
T
Which to keep 1979 Ford Mustang or 2013 VW Jetta TDI Sedan
  • toasterboy1
  • Sep 13, 2025
  • Off-Topic Hangout
Off-Topic Hangout Sep 14, 2025
toasterboy1
T
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
