  • SN95 4.6L Mustang Tech
rearend question
  • Thread starter Thread starter Drews02
  • Start date Start date Dec 14, 2004
D
Drews02
24
  • Dec 14, 2004
looking at installing locker. need input on which is best and will a locker for 28 spline axles be good enough or will it not hold up. all input appreciated
Tylerb59
Banned
Mar 7, 2003
1,895
Arlington, WA
Dec 14, 2004
  • Dec 14, 2004
Eaton Posi makes a great differential, I have the 31 spline version with Moser Axles.
D
Drews02
24
  • Dec 14, 2004
alright thanks. eaton was what i was looking into. id also like to know if i bought a 28 spline locker could it hold up to launhes on slicks from around 4000 rpms.
Tylerb59
Banned
Mar 7, 2003
1,895
Arlington, WA
Dec 14, 2004
  • Dec 14, 2004
If you're going with slicks, step up to 31 splines ... you might be able to get away with it with aftermarket 28 spline axles for a while.
You obviously have a much longer life and strength with 31. If you're looking for all out strength but only if you never take corners go with a 33 spline spool setup with C Clip eliminators.
That gets rid of your ABS, so hopefully you never get into a situation where big brakes are needed.
Be sure to weld your torque boxes and axle tubes for reenforcement when using slicks as well as a driveshaft loop.
If you're going to be using Weld rims, you're going to need 3'' wheel studs with open ended lug nuts.
D
Drews02
24
  • Dec 14, 2004
well the car is a daily driver and i rarely go to the track but when i do and want to do some hard launching i dont want to worry about breaking something and the car is N/A and i dont plan on any big power adder except maybe nitrous someday. so if i put the 28 spline locker in it should be fine since im not doing hard lauches that much. and also what rpm would be safe to launch at with slicks on the 28 spline.
Tylerb59
Banned
Mar 7, 2003
1,895
Arlington, WA
Dec 14, 2004
  • Dec 14, 2004
With a good burnout on slicks you'll be able to (almost) drop the clutch from just under redline or with a 2 step limiter to get going.
But that's when you're going to want a STRONG setup (forget 28 spline) and probably a good transmission / clutch to handle the abuse.
There isn't much of a price difference between a 28 and 31 spline setup, and if you're going to be replacing parts it only makes sense to do it right the first time instead of breaking something at the track.
Head over and browse the www.modulardepot.com forums and check out some of the videos. A few people have snapped axles on slicks, 31 even.
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
M
2001 SVT Cobra Decision Time
  • Mec
  • Aug 13, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 14, 2026
nickyb
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
F
T5 transmission questions
  • Forddestroyer96
  • Aug 27, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 27, 2025
Forddestroyer96
F
