Rearend Upgrade Suggestions
  • Thread starter Thread starter 66StangFastback
  • Start date Start date Dec 25, 2006
66StangFastback
181
norman, oklahoma
Dec 25, 2006
  • Dec 25, 2006
First off, let me say happy holidays to all.
I've managed to reel in some cash for Christmas and am looking to upgrade my stock rearend. I have the stock 8" rearend with 2.79:1 gears and an "open" type differential under my 66 Fastback. I was wondering what you all might suggest to me.
I'm looking to spend 750 or less, and the only requirements I have are that it has 3.55 or 3.73 gear ratio and a limited slip unit.
I've seen the full pumpkin units on ebay for about that price and was wondering what you guys thought of them? Seems a little high to me until you consider the demand on the webbed type casings as well as the cost for gears, LSD, and the install prices.
Basically I just want to know what all of you think I should do with my money. I've been saving up for gears for a few months now and am set on upgrading this stock rearend.
Thanks all.
Z06killinSBF
457
McKinney, TX
Dec 25, 2006
  • Dec 25, 2006
Summit 3.80 gears - $150
Locker center - $450
install - $200
It's what I'm gonna do.
rbohm
6,698
550
204
tucson,az
Dec 25, 2006
  • Dec 25, 2006
a powertrax and a set of 3.55 gears makes for a very good streetable combination, that will work well at the track as well.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Dec 26, 2006
  • Dec 26, 2006
install - $200
I hope your Summit 8" gears are better than the 9" 3:70's I bought from them last summer. First set of Summit brand had rust and corrosion on them and I sent them back. Second set was a little better, but still had a little rust where the cosmolene wasn't fully applied. I felt desperate and decided to install them anyways. This set whined worse than the ole' lady at her time of the month. I dropped them out, rechecked the pinion depth, tightened the backlash to the low end of the specification, and rechecked the pattern. All it did was make them sing at a slightly different mph. I've never had this issue before when setting up gears.
My cure was to drop them out and purchase an identical set of used Ford manufactured gears off of Fleabay. Now it runs quieter than a church mouse.
My point is that you need to watch those aftermarket gears--many of them say that gear noise is normal and should be expected. Buy some Ford manufactured gears (which are preferred by Nascar) or some Richmonds. Stay away from the cheaper alternatives if you can.
67Dylan
259
Phoenix, AZ
Dec 26, 2006
  • Dec 26, 2006
I bought only one set of 'alternative' gears myself... lesson learned. I like the FMS stuff and have used Richmond once as well, neither gave me any noise problems.
I also agree w/the powertrax rear. If you can install everything yourself you could save some of your cash for more parts. I wouldn't recmnd tackling it by yourself if you've never done it. Not a difficult job mind you, but it's nice to have the help of someone who's done it before.
ultrastang
1,092
Arkansas
Dec 26, 2006
  • Dec 26, 2006
If you've never set rear end gears up and don't have the tools to do it with, let someone with experience and the proper tools do the job.
www.ultrastang.com
dennis112
1,561
36
79
Dec 26, 2006
  • Dec 26, 2006
www.ultrastang.com
Sound Advice!
66forfun
260
Pittsburgh
Dec 26, 2006
  • Dec 26, 2006
my builder set me up with auburn pro posi/motive gear ribbed case. my drum brakes are in good shape and i just replaced the axle bearings 2 yrs ago. should be good for street tires. no drive till spring though...
coolblue65
1,224
Algonquin, IL
Dec 26, 2006
  • Dec 26, 2006
Ditto, thats my exact setup, and I have been very happy with it...especially with the Tremec.
Pbum5
515
Minneapolis, MN
Dec 26, 2006
#10
  • Dec 26, 2006
  • #10
You can always buy a rebuilt pumpkin that's ready to slap in.
http://cgi.ebay.com/ebaymotors/FORD...019QQitemZ290065183122QQrdZ1QQsspagenameZWDVW
Shop around a bit.
You can also get a complete 9" with gears for about that price if you wanted to go that route.
66StangFastback
181
norman, oklahoma
Dec 26, 2006
#11
  • Dec 26, 2006
  • #11
More on said powertrax? Where can I get one and about how much are they?
Does a "ribbed" type case for the 8" really make that big of a difference over the regular type?
I'm basically trying to do this right the first time, but with minimal cash spent because I'm also hoping to get a torque converter and tranny cooler in before spring. Thanks for the help guys.
66StangFastback
181
norman, oklahoma
Dec 26, 2006
#12
  • Dec 26, 2006
  • #12
By the way, this is a daily driver.
D
danny clemens
728
#13
  • Dec 26, 2006
  • #13
If it is a daily driver and you're not going to punish it too much I would think that the early center would work. I don't know anyone who's broken one but I don't know anyone who's drag raced them much with a lot of hp over stock. The ones with the extra ribbing are stronger but I really don't know how much.
66StangFastback
181
norman, oklahoma
Dec 26, 2006
#14
  • Dec 26, 2006
  • #14
I don't pound on it too much, but at the same time it does have stock wheels so I've only got a set of 215/70r14s on there, so it's not like I could get any traction. It most likely will see some track time in the spring, but will probably stay on cheapy street tires. The engine only puts out about 300 hp anyway. I've thought about nitrous but don't want to damage the rearend, so it'll have to wait until I can do a rearend swap.
So, checked out this Powertrax system many suggested. It seems like a really good deal at only $250, but would it be safe in my daily driver? It seems like a cross between a spool and a real LSD unit. Do any of you have first hand experience with one. I don't want to be chirping the tires at every turn, and I do drive it in the rain/ice/snow. Terrible I know, but I'm just a kid and can't afford to park it and buy another car.
67Dylan
259
Phoenix, AZ
Dec 26, 2006
#15
  • Dec 26, 2006
  • #15
Have you tried looking in Summit or Jegs?
67Dylan
259
Phoenix, AZ
Dec 26, 2006
#16
  • Dec 26, 2006
  • #16
That's not a bad price for someone that wants to just slap one in and be done w/it. If you know what you're doing and have the tools they are fairly simple to install yourself, as I stated earlier. I've installed three sets after I was shown how to install my first set.
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
