rebuild 302
N242
90
hi
i have 302 88 frome lincoln tc (not ho)
now i have this parts:
head e6se , Weiand Stealth Intake Manifolds and 4150 dp holley.
i want to rebuild this engine that it output 350-400 hp .
what is the combo that i need to buy ? (piston, cam, rods...)
thanks
Those E6 heads are only worth anything as a boat anchor.
I would say that you need to stroke it out to a 331, good set of AFR heads or TFS twisted wedges, custom cam, etc. I can't really help you out with the carb situation since it has been YEARS since I have messed with a carb.
The E6's are worse than the stock '87-'95 E7's which are pretty much worthless.
If you want some cheaper aluminum heads Texas Hot Rods has Patriot 185's for $850.
Youre probably going to want to convert the motor to a HO motor with a roller cam.
347 or 331 stroker kit with 10.1 comp , AFR 185 heads, and keep the stealth and the dp holley they will work. If motor is flat tappet cammed run a Comp 31-254-4 if roller cammed run a Comp 282 Xtreme Energy or something close that should give you 400 wheel horsepower
There are way to many variables with similar combinations that give different power numbers.
You really need to get rid of the E6 heads if you want to make some power.
You can get 350hp out of a 302/306, at the motor.
It is probably going to cost more than you realize, and yes I would convert to the HO configuration as well!
Good Luck!
i don't went to stroke the engine
i went to stay 302
i think to change the heads , up the compration to 10.1 (maybe little more), light rods
and roller cam ,
what are u thinking?
With you asking what 'pistons and rods', we just assumed you wanted to stroke the engine:)
How 'streetable' do you want the car? Is it a daily driver? Are you still running your air conditioning unit, power steering, etc?
350-370 hp is pretty attainable if you are willing to spend a little coin.
400 at the wheels is gonna cost alota money..... Isn't easy either.
On a 306ci engine I would go with a AFR 205 head, and a vic jr intake, and a big ass custom solid roller, but that is just the way I like to make HP :D
but then again, I have been wanting to make a h rev 302 for autocross also :D
i went to stay 302
and roller cam ,
Are you talking RWHP or FWHP when you say 350-400 hp?
Cause 400 RWHP on a 306 is gonna be costly and more than likely not very streetable. It will make power high in the RPM range and you'll have to wind it out. It can be done but we need to know more about what your plans are for the car.
400 302's cost coin and are not very drivable. The 302 in the Real Street car makes about 400 with a 180cc head extensively worked over and a cam that has 265/268 duration at .050 lift and is revved to the moon. That 400 horse mark could be more easily attained without the restrictions we have but expensive and short lived none the less.
