Ok well first of all if your going to do it do it right and have fun
1. Go to advance auto parts, (Or maybe another autoparts, but i work here so i know we have it) you can order the
HEAD GASKET SET this will include
A) Head Gaskets
B) Water Outlet Gasket
C) Exhaust Manifold Gaskets
D) Valve Cover Gaskets
E) Valve Stem Gaskets
F) Water Pump Gasket
thats what it brings for sure, i can check for sure and let you know by tommorow but you will also need
F) Oil pan Gasket
G) Timing Chain Gasket
H) Front Main Seal (Crankshaft Seal)
I think that is all for Gaskets. Now on to parts...
A) Push Rods
B) Valves
C) Oil Pump
D) Rockers
E) Valve Springs
F) Crankshaft
G) Piston Rings (Pistons depending on the condition of them)
H) Connecting Rod Bearings
I) Connecting Rods (Would make it stronger and last longer second time around)
J) Fuel Injectors (Just to be safe, But optional)
K) Water Pump
L) Hoses (As some of the old hoses tend to fall apart while rebuilding)
M) Fuel Pump (Might also be a good idea too)
You will also need to have the heads resurfaced.
I think that might be all but i still have a feeling I am forgetting some things but forgive me for anything i might have left out, And while i am at work tommorow i will look into it more and get some prices if you would like as well and tell you what the sets bring as well. Hope i helped:SNSign:
P.S.
What would also be a good idea is to buy a engine parts cleaner tub and engine parts cleaner to clean any parts you might be keeping such as the valve covers and brackets and so forth. It would also be a good idea that while everything is apart that you Completly clean the block, either with kerosine (If i spelled it right) or with engine parts cleaner.
