I have a 89 LX that I am going to star tearing into tonight after work. I am going to pull the motor tomorrw morning. I have blowby thru the exhaust and after a compression test a few weeks ago my highest cylinder was 160 and 2 of my cylinders were 130. The guy that owned it before me ran a Zex nitrous dry kit on it thru the intake 125 shot. He told me that the blowby started after the second shot. Talking to him he says my compression on that motor should be close to 200. I am not sure at what ratio. So with that being said. I am not rich by any means and my only intent by pulling the motor to work on it is to get rid of my oil consumption and my blow by problem and to have a car that I can drive back and forth to work without haveing to smoke people out. I will take it to the track here and there but I basically want it back to where it was before the idiot that owned it before me ran nitrous thru it and blew the rings. I only have around 750.00 to spend. That money has to cover the machine shop work on it also. The way the motor sits now is as follows:
302 .30 over
Edelbrock plenum and intake
75MM BBK TB
65CFM MAF
claims to have flat top forged pistons
cast iron ported and polished heads(step below GT40's)
303F cam
24# injectors
underdrive pulley
High volume oil pump
K&N air intake
Aluminum drive shaft
World Class T5
4.10 gear
302 .30 over
75MM BBK TB
65CFM MAF
303F cam
24# injectors
underdrive pulley
K&N air intake
World Class T5
4.10 gear
