Rebuilt engine question.
itz frank
Ok so I've had my eye on a 1990 5.0 coupe for a little while now and the car has quite a few miles on it. I was wondering how reliable a rebuilt motor is? Obviously, the most ideal method would be a new engine. But this engine has been rebuilt and modded. How reliable will it be? It's going to be my daily driver and this is why i'm asking. I don't want something I'm going to have a large amount of problems with. Another thing is that the engine was rebuilt 40k miles ago. Should it be rebuilt again? Anywhere to get a powerful crate engine for cheap? What would you suggest?
a properly rebuilt engine will rune great and should be very reliable and should run as good or better as a brand new engine.
if the rebuilt engine is 40k miles, thats notmany miles as the stock 5.0s that came with the car see over 200k miles and rune great b4 ever getting rebuilt..
if it has good oil pressure, no knocks and smoking then its good.
i rebuily my engine and it has like 3k miles on it so far and its runs AWESOME
I guess it all depends on who did the rebuilding. If i was looking to buy the car i would have it taken to a mechanic and have it inspected. have a compression test done and see what the cylinders are like. A rebuild is reliable i wouldn't worry bout that. You have to realize you are buying a car that is nearly 17 years old. things will probably go wrong with it. get it inspected best advice i can give you.
I understand the engine situation and i should have it inspected. I'm going to have $4k to put into the car for repairs and such. I'd just rather not. I really like this 90 coupe though. I just don't know what to do.
If you have a compression gauge test the compression and see how healthy the motor is. As someone earlier said, it depends on who did the rebuild, but they are usually reliable. Also ask for any documentation on the rebuild as it too easy to say 'it's a rebuilt motor' when actually they just had it steam cleaned to look new(er). If the tranny is the original and has never been replaced, depending on the mileage of the the rest of the car, I think I would probably be more worried about it. Also, look under the car for any signs of suspension or body damage, and check the torque boxes to see if they are intact. If you don't know what to look for then see if there isn't someplace in your area that specializes in Mustang's and can give some no bs answers. If it checks out, go for it.
