Alos, the turbo I have is pretty large for a 302. the 8 lbs right now is really out of the efficiency range. I expect it to go up exponentially when I start to turn it up.
Heres the build.
http://forums.stangnet.com/showthread.php?t=553614&highlight=begun
Heres the cost to the best of my poor memory
Turbo=625 shipped to my door
Intercooler=300 You can get them cheaper and nicer, but they lacked a few features I needed. Also had to farm it out since I can't tig. But that is changing as we speak.
Fuel pump=300
Fuel fittings/braided lines=275 10 AN IS EXPENSIVE
Oil relocate/lines and fittings=130
Headers+some help from exhuast shop=259
LM-1...AFR meter(Must HAVE!!)=349
Bonnet and regulator=75
Muffler=39
Catch can=25
K&N=45
BOV=200
Wastegate=200
Silicone couplers=230 Due to the lack of room in these things I needed a few 90 deg couplers. They have a shorter radius than metal.
Hose clamps=50? For intercooler
Carb mods=<50
Autometer guages=70
All = 3300 bucks
Look on face of a group of "tuners" when they hear the BOV venting and not having an idea of where the F it came from=PRICELESS
Come on, you didn't think I'd type all that and not do a priceless bit did you ?!?!
Now it can be done much cheaper. You don't have to run an intercooler with about 8-12 psi depending on CR. I wanted one. I know I am going to a bigger motor and MORE BOOST. So I just want to be able to drop in a better intercooler when that comes. So without that, knock off a ton of $$ I knew in advance I would build a 800hp street car when I find a block.
You can also use two stock turbos from turbocoupes for about $200. No 200 dollar wastegate(they come with), and save 400 bucks on the turbo.
There is a ton of money to be saved if all you want is 400rwhp. Best part is you can to it to a BONE stock 289-302 and get 400rwhp with 10 psi or so. Cast pistons and all.
