redline limits?
  • Thread starter Thread starter none67
  • Start date Start date Jan 3, 2004
none67
352
  • Jan 3, 2004
anybody know what the stock 289 crank and rods can take as far as RPM go? (i have a 302 block). I mean how far they will rev before they brake?
jcp123
408
Tyler, TX
Jan 3, 2004
  • Jan 3, 2004
you'll have to worry about the valvetrain more than likely before you gotta worry about the bottom end. but i wouldnt push stock stuff much more than 5500
10secgoal
2,801
San Diego
Jan 3, 2004
  • Jan 3, 2004
5500 is right if it's stock. That's when the rod bolts start to really stretch. The crank will go much farther than that. But remember the more Hp you make generally the lower that number gets.
U
usedtobe 67p51d
208
let's tear up golfcourses and build race tracks!
Jan 3, 2004
  • Jan 3, 2004
i ran my "stock " motor to 6k a thousand times,no bolts failed
blue66tang
1,092
Medford, OR
Jan 4, 2004
  • Jan 4, 2004
Put some good ARP bolts in and your good to about 6500.
F
Fostang
1,400
Stockton, Ca
Jan 4, 2004
  • Jan 4, 2004
My question is why do you want more than 5500 rpm when the crappy stock heads only support 4k half assed.
I've taken a 5.0 to 7k with with the factory rev limiter of 6250 removed. Can you save valve float and just no power.
none67
352
  • Jan 4, 2004
my engines just a little hotter than stock man
are the bolts the only real problem with the rods? or are they just weak to begin with?
HistoricMustang
2,359
Confederate States of America
Jan 4, 2004
  • Jan 4, 2004
A solid lifter unit will turn 7000 with no problem but they really stop pulling about 6200 so no need to go any higher unless you really have a high dollar motor.
Keep hydraulic motors lower as valves will float for the first few times. After that it may get ugly.
HistoricMustang
www.historicmustang.com
U
usedtobe 67p51d
208
Jan 4, 2004
  • Jan 4, 2004
my hydraulic roller motor is flat from 6k to 6.5k then falls from there. at 7k it's making 330 rwhp, @ 6.5k it's @ 343
F
fastback brian
540
So Cal , I.E.
Jan 4, 2004
#10
  • Jan 4, 2004
  • #10
stock rods with 5/16 arp 2000 bolt and a stock crank I say is good for 8500. Thats because ive been there and done that with three differnt 289's. The only rod failure was because of a broken arp 8740 rod bolt that was incorectly torqued.
10secgoal
2,801
San Diego
Jan 19, 2004
#11
  • Jan 19, 2004
  • #11
Now I didn't say they would break. Just said that's when they start to stretch. I've had stock rods with arp bolts. It saw 9400,oooppppss. Tranny missed 3rd.
G
GaPonyFarm
663
Columbus, GA
Jan 19, 2004
#12
  • Jan 19, 2004
  • #12
Your biggest problem with the stock 289 is the valve springs not keeping up with the high revs... Keep it around 5500, unless you're looking for a good excuse to drop in a new motor. Remember you have a 30+ year old engine...
G
gp001
4,401
So. Cal.
Jan 19, 2004
#13
  • Jan 19, 2004
  • #13
Just poot your foot on the gas until the motor blows. Your redline was somewhere before that
6Stang7
1,470
Livermore, CA
Jan 19, 2004
#14
  • Jan 19, 2004
  • #14
First your valves will start to float, then once you get to around 6000/6500 your block will start to twist. Now, I donno what year your block is, but I know back in the 60's Ford had a problem with there 289/302 twisting once you got that high. A main ladder is a great way to prevent this however.
-Shaun
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
T
Engine 1970 302 boss block
  • TOM B
  • Jan 4, 2025
Classic Mustang Specific Tech Jan 14, 2025
lqbbe
L
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
