  • SN95 4.6L Mustang Tech
redline
  • Thread starter Thread starter srt420psi
  • Start date Start date Jun 16, 2007
srt420psi
  • Jun 16, 2007
whats the max redline a stock internal 4.6 sohc can be safely run out to?
tomustang
Psychotic Member
3,434
McLean Hospital
Jun 16, 2007
  • Jun 16, 2007
6250 avg, why? It's not about how high your car can rev..
srt420psi
  • Jun 16, 2007
i was just curious. i dont plan on revving any higher than stock limiter.
Stus99GT
75
VA
Jun 16, 2007
  • Jun 16, 2007
The horsepower begins dropping off around 5800-5900. I always try to shift before I hit 6000.
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Jun 16, 2007
  • Jun 16, 2007
i moved mine to 6500 but thats only so when im racing other cars on the freeway i can hold it in 4th longer so when i hit 5th im not coming into it a 4k and bogging down.
i usually shift at 5700. no power past there anyways.
Crzyhrse
Seattle, WA
Jun 16, 2007
  • Jun 16, 2007
A 2V's horsepower is gonna drop off before that. Around 5,300RPM's. Unless you have aftermarket cams and such. The 4V Mach's peak horsepower is at 6,000RPM.
Stan Weiss
347
Philadelphia, PA
Jun 16, 2007
  • Jun 16, 2007
OK at what RPM you shift from one gear to the next has as much to do with trans. gear spread and the amount of RPM's loss / dropped after the shift as anything. A 3.37 first and a 1.99 second means a 41% drop in RPM after shifting. If I shift at 5750 RPM from 1st to 2nd my engine drops to 3395 RPM. The idea is when you shift from 1st to 2nd you want to have the same or more wheel thrust to accelerate the vehicle. Because the % drop is highest in 1st gear you will need to shift 1st at a higher RPM than the other gears.
the98stang
2,408
Clovis, CA
Jun 17, 2007
  • Jun 17, 2007
Every car is different, so you can't apply this to every stang out there. Ultimately, you can find the best shift points for your car by looking at a dyno graph.
O
Timing guide
  • oilleak1000
  • Oct 10, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 10, 2026
oilleak1000
O
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
I think Hot Wheels is trying to steal my identity!
  • LILCBRA
  • Mar 26, 2026
  • Off-Topic Hangout
Off-Topic Hangout Apr 10, 2026
LILCBRA
W
I have some 4.6 questions.
  • whiskerz
  • Nov 14, 2025
SN95 4.6L Mustang Tech Nov 25, 2025
squeak93
