badstang123
And I dont remember which side is which. But you are only supposed to fill from one side. I think its the side on the driver side.
This depends on whether you're filling the system with the car on or off. If the car is on you can use the low pressure side (Driver side) port. If you are doing it with the car off you have to use the high pressure side (Passenger side near the upper radiator hose). You also need the correct equipment for whichever you use. Most will find it far more simple to use the low pressure side with the kit from the auto part store.
- Justin
