  • SN95 4.6L Mustang Tech
Reflashed PCM and still having stalling issues!
  • Thread starter Thread starter stang09er
  • Start date Start date Jan 7, 2009
stang09er
115
Clarkston, MI
Jan 7, 2009
  • Jan 7, 2009
My car intermittently stalls out... i am starting to notice that a lot of us 1999-2001 GT stangers are starting to have these problems. This is a list of things i have done to try and figure my problem out because it is never ending and there is a little twist in my situation.
About a year ago i tried buying some cheap horsepower... it was basically a resister that got inserted into my MAF in order to trick the computer into thinking that it was colder than it really was outside. it sounded legit... more fuel + more air = more power! Well, it seemed like it worked until my car stalled for the first time! after that i took the resister out.
It still stalled out after that intermittently...so i did the following and none of it did a dayum:
-Replaced Fuel pump with new SVT focus fuel pump in case it was startng to go
out on me (more lph's)
-Replaced 6 coil packs because my engine was misfiring...codes were thrown
-Replaced all the sparkplugs
-Fuel filter has about 15000 miles on it so i let that go
-New FMS high performance clutch (AWWWWESOME...when the car doesnt stall)
$1440.00 later...the problem still persists!! so i took it to the Ford Dealer and they hooked up the laptop to run some realtime diagnostics while it was on the road... it refuses to stall while idling...seems to only do it intermittently under load!?!
the techs determined that the PCM needs to be reflashed. I couldnt buy a new PCM through the dealer because ford no longer makes PCM's for the 2000 mustang GT...it is discontinued! I sent my PCM out to Automotive Technologies in florida and got it back about 5 days later....with the same problem. i just blew $265.00 on a reflashed PCM (with a lifetime warranty) and i still have the same problem. sorry for the long post, but i need some help with this... the ford dealer couldnt figure it out and i am sick and tired of borrowing family members cars for days on end! i dont want to go out and buy a beater... i just want to justify spending the money that i already spent! Please help! Thanks in advance!
MaxedGT
304
Surrey BC Canada
Jan 8, 2009
  • Jan 8, 2009
The resistor that you plugged in at the maf sensor may have slightly bent the terminals in the connector and now aren't contacting properly. they may need to be replaced or rechaped to provide proper tension.
tag4car
Birmingham AL
Jan 8, 2009
  • Jan 8, 2009
Iac maybe? when i had one go out i also ended up getting a new ford pump put in, how "convenient" does the dealer know the maf was at one point modded?
stang09er
115
Clarkston, MI
Jan 8, 2009
  • Jan 8, 2009
Just got off the phone with the shop that is working on my car (im sorry all of you do it yourselfers...but i dont have the time or the patience to deal with this problem myself! i salute you if you do though!) IAC has been replaced but the problem still persists! i am going to try and replace the MAF sensor assembly that the resistor was plugged into! hopefully that helps! Thanks everybody.... for now!
tag4car
Birmingham AL
Jan 8, 2009
  • Jan 8, 2009
no problems!!, hoping that will be your issue, i think i have a stock maf around here
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
  • Gulftown980x
  • Jul 29, 2026
squeak93
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
