Relay Help
  • Thread starter Thread starter Black331Stang
  • Start date Start date Jan 8, 2004
1 of 2 Next Last
Black331Stang
1,485
Long Island, NY
Jan 8, 2004
  • Jan 8, 2004
i need to get a relay(30-40 amp) for my taurus fan so i went to the auto store and they had none on the shelves so i asked at the counter. Then they asked for car and year and all that garbage. And i said its for a fan and he looked in teh book and said its for 89-92 mustang elec fan..??? and they had to order it and it was like 50 something $...i thought i just needed a basic relay that splices in...what do they look like? i found something on ebay..would that be good?.....ill attach the link....and how much am i looking at for a 35-40ish amp relay? thanks for any help.
Relay on Ebay
Anthony.
Black331Stang
1,485
Long Island, NY
Jan 8, 2004
  • Jan 8, 2004
o and i really need to get this relay asap...so quick help would be awesome.. thanks
TIMMY2734
1,330
Queens, NY
Jan 8, 2004
  • Jan 8, 2004
Your best bet would be to go to an audio shop. they usually have tons of stuff like that. I picked up my 80 amp relay from one around me for about $27 i think. I couldve gotten it cheaper online, but i guess it wasnt too bad for a store bought item
Black331Stang
1,485
Long Island, NY
Jan 9, 2004
  • Jan 9, 2004
hmm wierd i replied to your post yesterday and nothing came up
Anyway thanks for the suggestion...ill stop by there today....
And come on guys i know liek 75% of u have electric fansssss lol
gaslight
3,365
Maine
Jan 9, 2004
  • Jan 9, 2004
how about trying radio shack.
Black331Stang
1,485
Long Island, NY
Jan 9, 2004
  • Jan 9, 2004
hmm..another good idea...thanks..are they sorta like inline fuses design wise? one wire in and one wire out?
T
TheUser
1,859
Springfield, MO
Jan 9, 2004
  • Jan 9, 2004
for what it's worth, I just got a fuel pump relay yesterday from a ford dealership for like $17...not sure what size it is though.
Black331Stang
1,485
Long Island, NY
Jan 9, 2004
  • Jan 9, 2004
anyone else?
TIMMY2734
1,330
Queens, NY
Jan 9, 2004
  • Jan 9, 2004
The relay will have 4 posts or terminals on it
TIMMY2734
1,330
Queens, NY
Jan 9, 2004
#10
  • Jan 9, 2004
  • #10
I checked radishacks website for you and they only have 30amp relays.
http://www.radioshack.com/product.a..._name=CTLG_011_002_013_000&product_id=275-226
Any quality audio shop should have a decent assortment of relays available to pick from.
HISSIN50
34
129
Jan 9, 2004
#11
  • Jan 9, 2004
  • #11
Brodeur, if you havent, skim through this. as i recall, it has links to places to buy what you need and prices (outdated?). sorry cant help more, still have mech fan.
good luck.
http://www.geocities.com/smithmonte/Auto/MarkVIII_Fan.htm
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Jan 10, 2004
#12
  • Jan 10, 2004
  • #12
NONE of the relays mentioned should be used for the fan - you need a heavy duty relay - find an auto parts store that can supply a Bosch relay #0-332-002-156. I think it's rated at 75 or 80 amps. It will have four terminals. Two for the 75 amp power to go through and two for the coil used to close contacts and send the 75 amps through the relay.
try www.bpg-inc.com - don't know if it's still good but try it. ~$15
Black331Stang
1,485
Long Island, NY
Jan 10, 2004
#13
  • Jan 10, 2004
  • #13
cool...so a radio shak one wont be good at all??? should i just give the auto store that part number
HISSIN50
34
129
Jan 10, 2004
#14
  • Jan 10, 2004
  • #14
TMoss is right on. that is the relay used in the link i gave. price in the article was ~23 bucks, IIRC. you could try calling around for that part number, but dont know what kind of luck you will have. i think the link provides a company and number to call.
also note, as i recall, the coil terminals for THAT relay are not interchangable, IIRC. i.e., 85 = ground;86 = 12volt trigger. you cant interchange them, as you can on a normal SPDT relay. check instructions.
good luck.
Black331Stang
1,485
Long Island, NY
Jan 10, 2004
#15
  • Jan 10, 2004
  • #15
so this relay that i have (pic) wont be good even if i have a taurus (less draw) fan and not a mark 8. And everyone that has an electric fan has (or should have) the bosch relay you are describing? (or equivalent contact rating? so worst comes to worst i can use this relay for my foglight rewire.
and how do they work? u just stick the wire thru the posts and find a way to get it to stay? they look liek a PITA to wire up. thanks guys.
EDIT: i wasnt thinking....u most likely use the female connector things right?
TIMMY2734
1,330
Queens, NY
Jan 10, 2004
#16
  • Jan 10, 2004
  • #16
They are very simple to wire up. For that relay, you need to use a female spade connector on the end of the wire. Then you just slide it over the terminal. For the larger relay, your probably going to use ring terminals. It would also be a good idea to pick up some shrink tubing so that you can protect your connections from the weather
Black331Stang
1,485
Long Island, NY
Jan 10, 2004
#17
  • Jan 10, 2004
  • #17
k thanks.....sorta ignore this pic, its for HISSIN50 to look at for me.
TIMMY2734
1,330
Queens, NY
Jan 10, 2004
#18
  • Jan 10, 2004
  • #18
looks right. you just need to find a 12v source to hook up to other part of your switch
Black331Stang
1,485
Long Island, NY
Jan 10, 2004
#19
  • Jan 10, 2004
  • #19
o so the othr part doesnt get grounded? how bout teh radio remote turn on?
o and hissin....how big of a fuse between the !@V in and solenoid should i use? and is it really needed?
TIMMY2734
1,330
Queens, NY
Jan 10, 2004
#20
  • Jan 10, 2004
  • #20
You only ground one part, and thats on the relay. The other post uses 12v. Thats why you need the power from wherever you get it and run it through the switch. Got it?
You could buy a switch that glows up when its on to let you know when your fan is running. If you do get that type of switch, then youd have to ground it. For my 12v source, i found this knife blade fuse holder. You put it in an existing fuse holder and then it gives you an extra one.(2 from one slot) and then you solder or crimp the wire to where you need it
1 of 2 Next Last
84 turbo fan not working.
  • bdub_mkg
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2026
AeroCoupe
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sunday at 5:31 PM
roldy
R
Fuel fuel pump relay?
  • maxine-70
  • Nov 30, 2023
2K
Fox 5.0 Mustang Tech Dec 4, 2023
Shawneebear93
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
