Folks my car is going threw release bearing like nothing. This is going to be the 2nd one within like 10 months that is squealing when I either barley press the clutch pedal or if I am sitting there @ idle not pressing the clutch pedal. If I press the pedal about 1-2"s the squeal stops. Clutch is working normally. I replaced the clutch this past summer with a close to O.E clutch from 50resto. My car has hardly any mods, so no need for a super clutch. The car has 89,000 miles on it. Original T-5.
I was told to get an adjustable cable and see if that would work, that possibly the original cable is stretched?
It is the original cable. Now once the bearing is replace it is quiet for 3-4 months, and then the squeal starts.
I am tired of pulling this transmission down to replace it. Yes I used a Ford part. It can't be the clutch because it did it with the original clutch that was in the car as well. However just not in that short amount of time.
Is the cable what I need? Or do you have a different remedy?
. I am tired of pulling this transmission down to replace it. Yes I used a Ford part. It can't be the clutch because it did it with the original clutch that was in the car as well. However just not in that short amount of time.
I'd even go so far as to say replace it whether it needs it or not.
