Remove scratches from flat black molding?
  • Thread starter Thread starter Power4
  • Start date Start date Jul 1, 2008
Power4
200
Rochester, NY
Jul 1, 2008
  • Jul 1, 2008
Anyone know how to remove scratches and scuffs from the black molding areas on the 'Stang? (i.e. the side mirrors, the trim around the window, etc.) Will stuff like Scratch-X work for that?
04sonicblueGT
80
  • Jul 1, 2008
if it is deep and there is plastic that has been torn away there isn't much you can do. If it is minor, i am sure someone won't agree with this, i use a heat gun on low and slowly heat it up then is something with a mild texture to rub the scratch out.
If it is deep, i have used this on interior plastic panels, find a crayon that is a perfect match and color in, followed my mild heat gun , then repeat crayon - heat, till the scrath is full.
Power4
200
Rochester, NY
Jul 2, 2008
  • Jul 2, 2008
They're not very deep at all, just annoying little scratches. Think a hair dryer would work instead of a heat gun?
04sonicblueGT
80
  • Jul 2, 2008
yes hair dryer should be fine, just be careful not to over heat it, you don't want to melt it, just get it a little soft.
D
Rust on Window Belt
  • DuluthFoxbody
  • Nov 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 4, 2026
DuluthFoxbody
D
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
