Removed alarm no ignition switch now please help ASAP
strattoc
188
Cali
I just recently removed an aftermarket alarm off of my 88 GT, I had to use the valet button to start the car when I bought it, it would never just start with just the ignition switch itself. So because I didnt have the remote and dont care for the cheap alarm system BS I removed it. The car is a 1988 gt with 5.0 and automatic.
I cant start it by bumping the starter relay (hate doing it), I know fuel and ignition is good. I hooked up one wire at a time to the matching color, it was mainly the drivers side door wires (windows and locks), but in the harness next to where the door wiring is located in the drivers kicker there was one wire (black or dark brown) that was not hooked to anything, I also found the other end with the rest of the harness, I reconnected it but it didnt affect it. I've been trying to find diagrams for the wiring with no luck, but i want to say its the ground wire, the valet button hooked to a ground and then into the alarm box. I want to hook it up but am afraid if its not a ground wire I could mess something up. Here is a picture of the connector and wire, please help I need to fix this ASAP.
Do you have a multi meter and a test light? If the brown wire in question was hooked up to your alarm, it is most likely your parking light wire. test either end with your meter when turning park lights on/off. The 12v/accy/ign/start circuit if fairly simple....sounds like you may have other problems
I cant start it by bumping the starter relay (hate doing it).......
You can or cannot start it this way? The comment about hating to start it that way made me wonder.
Do you know which wires were attached to the starter kill relay? Very often, the interlock circuit is cut and each leg runs through the NC and common terminals on the starter kill relay. If this is how yours was done, the interlock circuit needs to be restored (the cut legs need to be reconnected).
On the valet switch, are you sure it was not a momentary switch wired into the interlock circuit?
No Crank checklist for 5.0 Mustangs
Revised 05-Oct-2010 to update Fluke references.
No crank. slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of both no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a know problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstuck and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachment.php
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachment.php
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachment.php
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
attachment.php
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Yes I meant to write can jump it.
I finally got to do some research before I came to this thread, and you guys are correct the brown wire is parking lights (glad its reconnected anyways). I dont have any meters or any way of testing these things.
From what I read the red/light blue wire is what should be disconnected on the ignition harness. It was just a momentary push button to crank it, one end of which is a ground and the other runs into the box. The alarm is a Code Alarm PRO 1000 SX.
Where would the neutral safety switch be at? is it part of the shifter? I just need to trace that wire out and see where it goes and if its been messed with my only question is that the neutral safety switch gets 12v to it and the switch was a ground, at what part of the ignition system would you be able to interupt the ground? If that makes sense
The red/lt blue or white/pink wire is likely what was cut if a conventional starter kill relay was used.
If the aftermarket momentary switch grounded something in the box to close the interlock circuit, that's not something you should have to mess with anymore. The cut interlock wiring was open and closed from within the box via the momentary switch's grounding path. Restoring the OEM interlock wiring should fix things.
The NSS is on the driver's side of the trans IIRC.
Ok so I did some investigation on my lunch and I found this..... It aparently needs some kind of relay hooked to it, on another wiring diagram it said timing circuit but I cant find anything else about it. It has 2 grays, 2 white/pink, 2 red/yellow and a black. There is nothing attached to it. Does it need anything?
I think that the diagram you posted has nothing to do with your problem. The text says low oil quantity indicator. That's a red light on the lower RH instrument cluster in GT models. It comes on when the oil gets below 4 quarts. It's absence or presence does not prevent anything from operating except the warning light.
problem solved, I found a connector stuffed way up in the dash that didnt look factory ended up being 2 red/light blue wires, spliced them together and boom I've got an ignition switch again.
Nicely done!
For the starter kill, instead of cutting the interlock wires, the installer might have removed the clutch-safety-switch jumper and used that as the in/out for the starter kill. If this is so, you might be able to find a CSS jumper (from another AOD car) and install it (if you want to restore the wiring to factory).
