  • SN95 4.6L Mustang Tech
Removing computer
  • Thread starter Thread starter Screamin' Demon
  • Start date Start date Mar 19, 2004
Screamin' Demon
204
winchester, va
Mar 19, 2004
  • Mar 19, 2004
Got my SCT chip and I need to put it in. I removed the kick panel but which skrews and what not do I remove to get the comp. out so I can put the chip in? If you guys have any tips leme know.
03Sleeper
464
Fordville,USA
Mar 19, 2004
  • Mar 19, 2004
hmmm
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 19, 2004
  • Mar 19, 2004
small metal bracket has one or two bolts in it , take that off and unplug the harnesses that are there and then there is one tiny screw/bolt that is holding a white strap on the corner of the computer , take that out and bend the white strap back and slide the computer down and pull it out .
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Mar 19, 2004
  • Mar 19, 2004
Yea just remove the white strap.. then remove (It will not come out.. just loosen it) the bolt of the thing that attach at the bottom of the EEC (the square thing)..
J
JOHNS01GT
209
Vermont
Mar 19, 2004
  • Mar 19, 2004
My car is an 01 so I don't know if anything is different on your 97. After removing the kick panel, there should be three connectors. Green and grey I believe, the middle one slides out and the other two need to be pulled out. There is a small gold hex bolt that holds a plastic white casing to the computer. Remove this bolt. It requires a 5.5 mm socket(stupid ford). Then pull the computer out. This is quite a pain in the rear. There is one more bolt holding the computer to the wires. It's on the bottom and it needs to be loosened. I believe it is a 10mm. Loosen it, and pull it apart. And your computer will be in hand! As for the chip I don't know, I just know how to remove the computer. Enjoy, hope this helps.
Screamin' Demon
204
winchester, va
Mar 19, 2004
  • Mar 19, 2004
Thanks guys. I should be ok now. Ill let you know how it went. Later.
Dr. Wu 2000
554
Eastern, Pa.
Mar 19, 2004
  • Mar 19, 2004
When you install your chip be careful. If it is anything like the Diablo chip
it can be tricky prepping the board. My board needed to have the goop on
the connector removed before you could install the chip. I don't know about
the 97', but my 2000 you needed to take a brillo pad like piece of cloth provided by Diablo to remove the goop and take enough material off to
expose the soldered part of the chip. If you take off too much, you can
damage the cpu and possibly cause the chip not to work properly.
If you install the chip and it does not start, you probably didn't clean off the
solder well enough and need to go back and clean it some more. Just be
careful. I would hate to see you damage the cpu or the chip. Good luck.
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
